Question about Roper RAS8445KQ Top Load Washer
Inglish washer spins sometimes and doesn't othertimes
Washer sometimes spins and sometimes doesn't.Have tried on all different cycles.have tried switch and doesn't make any difference. Complets washand rinse cucle but won't spin. Your help would be appreciated. Thank You
I had the same problem. to solve I pulled of the cap where you add the Softener, Cleaned it , then look down the hole that is left in the agitator wheere the softener cap was, at the bottom is a plastic cap over the screw that keeps the agitaor on, pull this cap off and chedck trhe four dog that engage the saw teeth around the agitator, if they are there (shich mine where ) cleanall around. I used Fantasitc and poured it down the to fill up to the dogs. I manually turnee the agitaorthen flushed with hot water. It helop me. you got to be careful as the soap , like fantastic is slippery and the dogs will just slip if the soap is not cleaned all off;.
Posted on Jul 08, 2007
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
At the end of the cycle prior to spinning the washer sometimes doesn,t start to spin, it just makes sounds like it,s trying to spin but won,t catch. If I open and close the lid it begins it,s proper cycle....
The timer is not allowing a cycle stop for the neutral pack to drop. Replace the timer and you should be in good shape. The whistling sound is likely something in the pump.
Kelly
Mar 21, 2011 | Whirlpool Washing Machines
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Error codes "f1" "f22" etc. and washer stops at different times
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore 12502 won't spin
The lid switch is broken......
Oct 05, 2007 | Kenmore 12502 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
255 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
