Question about Aqua Flo Aquaflo Flo - Master Fmhp 1 1/2 Hp 115/230v Pump Pmp Aqf 020150001010
My pump is very noisy and the jet power is reduced.
It sounds like the intake area is where the noise is coming from
  • jillyp949 Feb 28, 2009
    my pond pump works well for about 1/2 hour, after that the flow of water in the waterfall reduces to about 1/2 the normal flow. Pump sounds a bit louder than ordinary. I've checked the impeller & water level. What can it be?
  • 49 Answers
Sounds like you got a stick or rock in it. If not, the pump impellers and shift are bad and need replacing.
Posted on Nov 28, 2008
My new black glass double door fridge and freezer is so noisy it actually wakes me up.Please help.Les
Les,
The nature of the noise can tell you a lot. Is it a smooth compressor sound that is excessively loud? Is it metallic like a fan blade might make if it is hitting something? A squeal like a failing bearing might make? Is it constant? Intermittent? Has it always been there?
I assume the fridge, other than noisy, operates correctly and normally.
You can add acoustic foam to reduce the noise (Find "Black Hole" acoustic absorbing foam or similar). If doing this, you cannot impede the airflow to the heat ex-changers or the compressor motor, or you could drastically shorten the life of your appliance.
You should also try and divine where exactly the noise is coming from. Lacking a stethoscope, a 1/4 " wooden dowel, placed against various areas on one end, and the other on the little skin flap of your ear, will safely telegraph mechanical vibration to your ear, allowing you to localize problems. Once you know exactly where the sound is coming from, it may be easier to correct the noise.
Mar 17, 2018 | Refrigerators
Winding noise on the left handside of car, what can it be? some is say is time belt some say its the power stering bell
Hi Alvaro, well based on your description it could be a few things! Firstly when you say left of car, is that as you look at it from the front, ie. you mean driver's side? If so then a whining noise will most likely come from the alternator and/or belt. That's the simplest area to check and eliminate first. Otherwise it could be the water pump which is driven by the timing belt. Replacing the water pump is not a major job but requires removal of the timing belt. I believe the power steering on your car is electric and if that's playing up you would most likely have a warning light on dashboard. Now, if you mean the passenger side when you say left side and you also talk about noise being present when you are driving along then it could be any of the following: wheel/tyre rubbing on something, noisy gearbox, noisy driveshaft/CV joint, wheel bearing, noisy clutch. So really need you to be a bit more specific about the type of noise, where it's coming from and when to help. Otherwise you'd best pop in to your local garage for diagnosis. Hope that helps. Andy
Feb 05, 2015 | 2002 Fiat Punto
My 2004 deville sounds like a jet engine when it starts. The sound goes away after it warms up I was told its secondary air intake. What needs to be fixed how do I replace it and where do I find the part?
Hello: The noise is from the air pump. This pump puts addition air in the exhaust to help burn the extra gas the engine gets when it is cold. If the pump is extra noisy it probably needs replacing. It is located in front of the drivers side front wheel. You have to remove the bottom splash guards to get to it. It may be a dealer item only but you can check with aftermarket stores to see if they have it. It is normal to hear a low whistle when it runs. Does not run very long.
Nov 01, 2010 | 2004 Cadillac Deville
Makes noise but jets do not work
Is intake clogged? sounds like impeller has come loose from pump if not.Take a garden hose and feed water back from a jet(closing/plugging others) to see if it flows back out intake checking for obstuctions. Are jets all the way open and water level well above intake?
Oct 04, 2010 | American Standard Cambridge 5' Americast...
Intake valve make a vibrating noise after a few minutes
From what you are explaining it sounds like the pump is taking on air, which I have seen when the water level is just a tad low & the pump creates a "vortex" at the skimmer box & air is sucked in. Double check the "flap" at the skimmer to make sure it is working properly (not stuck upright)
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Seems to be no pressure . water spray jets noy
sometimes if dishes aren't rinsed well food gets caught in the pump intake reducing flow,try clearing intake of pump
Jan 31, 2010 | Dishwashers
When on spin cycle makes noise & water comes out under machine. How do you take off back of machine to get to the pump area ?
Possible drum bearing problem , seals leak into bearing chamber and beyond , bearings seize and become noisy. Pumps get noisy but rarely leak.
Nov 09, 2009 | Washing Machines
Hi, i am using a Honda Civik EK3 1996, recently i changed Clutch / Pressure plate and timing belt, But now i am getting a Grinding sound (very noisy grinding sound like TV channel is not tuned ... ) when...
You may have to do some testing...if it is coming from the belts, start disconnecting them, don't drive the car since you will loose the power steering, but see if the noise still exists. Then if it does, is it coming from around the timing belt area, which brings me to my next question, has the timing belt been changed? Even if it isn't the area of noise; it needs to be done, and the water pump has to be replaced at the same time...location of the grinding noise is important in order to diagnose properly.
Oct 27, 2009 | 2004 Audi TT
Noise from transmission area
Sounds like the clutch through out bearing might be bad.Is it hard to shift?Does the pedal come up high befor the clutch engages?
Mar 29, 2009 | 2000 Mitsubishi Eclipse
Air ducts are noisy
Many heating/cooling ducts are metal, so they conduct noise quite readily from the air-handling unit to your rooms. To break the conduction of sound, you can have a heating contractor insert flexible insulation ductwork between the heating/cooling system and the ductwork runs. If you hear a pinging or popping sound coming from the ductwork, this may be caused by thermal expansion or by air blowing past a loose flap of metal. Track along the duct runs, listening for the sound. If you find it, make a small dent in the sheet metal to provide a more rigid surface that?s less likely to move as it heats and cools.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Aqua Flo Aquaflo Flo - Master Fmhp 1 1/2 Hp 115/230v Pump Pmp Aqf 020150001010 Logo
254 people viewed this question
Top Aqua Flo Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Aqua Flo Garden Expert? Answer questions, earn points and help others
