Question about Microwave Ovens
My GE Advantium model SCB2001 just died. I had two or three power outages earlier in the day. I reset the clock each time and the unit seemed to be O.K. I was heating a plate of food in the microwave and it just stopped. No lights or anything shows on the display, and no interior light. I figured that a circuit breaker had tripped and so I flipped the appropriate circuit breaker, but that had no effect. There appears to be no power to the unit.
  • Microwave Ovens Master
  • 1,879 Answers
Can you access the FUSE to check it. Frequent outages results in power surges and that's what the fuse is about, protects from inside (short-circuits) and outside (surges).
Posted on Nov 11, 2008
  • 13,433 Answers
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
I have a GE Advantium microwave model 2001 scb2001 03. It stopped working in the middle of a cooking and power goes completely out. A few days before that there was metal odor when using microwave
Betty, it sounds like you might have 2 problems and the power shutting off could be an end result of the metal odor you described. The power shutting off, more than likely is just a blown fuse. That is usually a simple and in-expensive repair. The metal odor could come from either your magnetron or from the high voltage transformer. Either one of those is going to be a rather expensive repair and if repair part stores in your area are anything like in my town, unless you repair them for a living or know someone who does, you can have some difficulty in getting those parts. Sorry for the bad news, but it might be simpler to just replace the microwave.
Feb 05, 2015 | GE Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
The display on my GE Advantium microwave oven shows "LOCKED". I tried holding the clear/off button but it won't clear. the microwave is unusable at this point
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If yours is an Advantium, one of these owner's manuals will help you set the clock if you need help:
http://www.microwavedisplay.com/sca1001kss_om.pdf
http://www.microwavedisplay.com/sca2000_sca2001_om.pdf
If you still need help, note that FixYa's Web site is currently not notifying us Experts when replies to our Clarification Requests are posted, so please post a new help request, but be sure to include your full model number from the tag in or on the unit.
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave power seems to have died
My advantium 120 died and it has power to the oven but it does not work! does the oven have a fuse that i can change?
Sep 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
I have a GE profile advantium oven. The oven seems to operate, however the green display is blank with a dash in the upper left corner. Cannot set clock or get any written information from the green...
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE Microwave Ovens
Gibberish on the Front Screen
Try unplugging the unit for 30 seconds then plug it back in. The power outage may have been erratic and the MW did not reset properly.
Jun 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
