Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water flows into machine when off
Kenmore Elite HE3 washing machine about 4 years old will sometimes fill with water after end of cyle and machine has turned off. Sometimes water does not continue to flow into the washer but when it does, it just keeps running and will overflow. Sometimes it is just a drip or sometimes its a steady flow. We are on a private well and the pressure is set at low-50 & high-70. According to the manual pressure range can be between 20-100 so this should not be causing the problem. We thought at first it might be sand getting stuck somewhere in the machine but we had a sand filter installed 6 months ago which did not solve the problem. Does anyone know if there is a pressure switch/valve that shuts off the water flow inside the machine which could be broken?
  • 1 more comment
  • Dale Cullen Nov 10, 2006
    catriver
    The model number I got off the front of the machine is 110.42822201. I did some more research on the net and I had a feeling that was what was wrong. Nice to have it confirmed by a pro! Thanks.
  • Bling4You Mar 01, 2008
    HE3T Sears, Model #110.42924 - I just tossed a towel into the empty washer only to discover there was water in the washer! I've also noticed that the clothes don't seem to be wringing out nearly as well as they used to. Help!
  • wamcgeemd Mar 10, 2008
    HE3T washer....3 years old. Water continues to drip into drum after the cycle. So much so, that if **t cycled after a day or so..will actually overflow and drip out the closed front door!
    From what I read here (very..very helpful!!) appears that the inflow valve needs to be replaced. I'm a reasonable "handyman" though by ** means formally trained. Can a "do it your selfer" handle this problem??
    Thanks!!
    President:
  • 878 Answers
Carmel, I've seen this a number of times on the HE3, you are going to have to replace the water inlet valve. Since it's filling after the end of the wash the pressure switch is not going to detect the fill. The valve is not closing properly. If you post the model number I can give you the part number. It's an easy fix, remove the top and the valve is right there. If you need any assistance in changing it you can email me at stp43ron@yahoo.com Catriver..post back.
Posted on Nov 10, 2006
  • Ron Marek
    Ron Marek Nov 10, 2006
    Carmel, your part number is...8181694. Catriver.
Why does my Kenmore Elite HE3 fill with water when it's off
The water valves are leaking usually from grit in the seat of the valve. They are a pair and can be easily replaced.
Aug 03, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My kenmore elite HE3 fills up with water when it is not running.
Hi... if your Washer is filling and its not running... you need a new water valve
Mar 30, 2011 | Kenmore Elite 45986 Front Load Washer
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore elite HE3 washing machine has low
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2009 | Kenmore Washing Machines
Water won't run into washer - clicking sound only front upper left like plastic gears running over each other
The fill valve is likely bad.
Jun 01, 2009 | Kenmore Washing Machines
Water seeps into my Kenmore Elite HE3 washer went is not in use. Does anyone else have this problem?
You are going to have to replace the water inlet valve. Since it's filling after the end of the wash the pressure switch is not going to detect the fill. The valve is not closing properly. It's an easy fix, remove the top and the valve is right there, te part number i think is 8181694
Mar 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3
THE PROBLEM YOU HAVING IS A VERY COMMON ONE THAT WE EXPERINCE BACK HOME.YOU COULD HAVE ONE OF TWO THINGS THAT COULD BE CAUSING THAT PROBLEM.FIRSTLY YOUR PRESSURE METER WHICH CONTROLS THE WATER FLOW AND CUTS THE WATER OFF WHEN THE LEVEL IS CORRECT COULD BE FAULTY.SECONDLY THERE IS A PIPE WHICH IS CALLED THE SUMP HOSE COULD BE BLOCKED WITH OLD SOAP AND DIRT THAT COULD ALSO OBSTUCT THE AIR FLOW TO THE PRESSURE METER.HAVE THOSE TWO THINGS CHECKED OUT.GOOD LUCK
Sep 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
180 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
