Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Water Leak at bottom of unit
My Bosch SHY56A05 has a leak that fills most of the compartments in the plastic containment pan at the bottom while running. I have removed the door front and toe kick plate and looked at what I can get to while the unit is running, but cannot see where the leak is coming from. I even had the unit out and on blocks while running, but could not see much more. I assume the leak is occurring somewhere underneath the unit. Any specific areas that are prone to leaking that I should concentrate on?
Thanks,
    Sergeant:
  • 409 Answers
leaks a quite frustrating once they happen but there aren't that many places that you can have a leak. i would recommend looking at the drain pump and ensuring all seals are ok. after that focus on the door itself. are the seals okay, the door liner, etc?
Posted on Nov 16, 2008
Bosch dishwasher will not take in water after cut off and restore of external warm water supply. Pump runs, aqua stop slightly warm and red tap /faucet signal comes on. Tried tilting.
your dishwasher is leaking water. the bottom or base of the unit is like a big catch pan, the pan has a water sensor witch is two metal contacts positioned just over the bottom of the pan. As water from a leak begins to fill the pan and makes contact with the two metal tabs it opens the circuit to a cut off switch at the water inlet valve. Slide the unit out from the cabinet just far enough to access the sides, about 20 inches, As water is removed from the panand no longer making contact wit the water sensor power will be restored to the inlet valve, Now you begin looking for the source of the leak, You may need to start a wash cycle, this is why the unit needs to remain connected. The source of the leake will dictate what needs to be disconnected and position of the unit. Something like the water level sensor can be replaced without fully uninstalling the unit.
Aug 18, 2015 | Bosch Dishwashers
My dryer is leaking from the bottom. service man said either the tube or the pan is cracked. tube seems ok, so is the pan replaceable or glueable. could there be another reason to look for leak. dryer has...
Open the bottom front panel. Remove the heat exchanger. Take notice to see if theres any water in that compartment. Reach your hand towards the back of that opening to see if there is water pooling back there. If theres water present, then your condensation pump needs to be replaced.
also double check the connection of the drain hose from the dryer to the drain.
Jan 09, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Bosch she4am16uc/01 not filling with water, can hear what I think is teh pump starting then it just sits there. Autoclean light just flashes and I cannot reset the dishwahser... any recommendations?
pull the dishwasher out and look inside the pan you more than likley have a leak and this is why it is not filling it has a safety so when it leak it will not fill with any more water.
Dec 27, 2009 | Dishwashers
Why does water occasionally leak from bottom of
There is a pan at the bottom of the unit. It catches the defrost cycle water and the heat from the comp. and condensor helps it evaporate. But, it's plastic. Mice have probably chewed holes in it trying to get at the water...They must have water to survive, right? Remove it and you'll see the holes....Then, replace it or epoxy the holes in it with plastic layering from old butter containers etc.
Aug 04, 2009 | GE Profile PCF25PGW Side by Side...
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
No fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
Sep 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher will not fill with water
without a brand or model number its hard to be sure, but some types have a float cut out switch inside the washer. Its on the bottom inside and kind of resembles a plastic mushroom. The top should lift up and down easily. detergent will clog it up and keep it from moving. Just clean all the soap caked on it and move it up and down to see it it pushes a little switch underneath.
Nov 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Oct 15, 2007 | Maytag MZD2766GES Side by Side...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
214 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
