Monitor goes black every couple minutes - Computers & Internet
    Sergeant:
    Champion:
  • 275 Answers
Which computer u have ?
i mean what brand?
Posted on Nov 11, 2008
  • Ali Khambati
    Ali Khambati Nov 12, 2008
    okie after it goes off how does it come on?
    try safe mode and tell me
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
While i am on my computer my hp w1907 monitor goes black. if i shut the monitor off and wait a few minutes it will come back on but then it only stays on for a couple minutes and goes black again.
This sounds like a power board problem. Could be failing power capacitors, which are allowing the charge to leak ( stripping the screen, not recommended) will show bulging or leaking capacitors). Or it could be an issue with the PCB. The fact it will restart once it has "cooled down" points to this.
I'm assuming you have tried the monitor on a different computer, just to eliminate the graphics card (unlikely but worth a go)
Solution..get it checked by a qualified TV repairman, it may a be a simple fix.
Jul 13, 2011 | HP w1907 LCD Monitor
After a couple of minutes operation the screen goes blank. Switch the power off for 30 seconds and it refreshes and works ok for a couple of minutes tahen repeats all over
the problem of ur monitor is the power supply board,it is located in the inner part of ur monitor,technician is allowed for that problem.you need to call a technician for repair.
Oct 03, 2010 | Westinghouse L1928NV Monitor
Monitor goes black after 10 minutes. Turn it off ...
Change eletrolitic capacitor in the power supply which is deformed.
WARNING: RESPECT THE ESPECIFICATION OF THE EACH CAPACITOR AND POLARITY!!!
Black side = Negative (-)
This video show you how to
http://www.youtube.com/watch?v=YCSNWi3UHf4
Best regards,
May 16, 2010 | Computers & Internet
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
Monitor Turns Black
Try reseating the Graphics card first..It may be loose. Or try it in a different slot.
May 21, 2008 | LG Flatron L1715S 17" LCD Monitor
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
