Question about HP DeskJet 812c InkJet Printer
My printer wont print in color & its a new color ink cartridge
I bought a new black and colored ink cartridge for a deskjet 812c and only the black ink is working. i cant get it to print in color
Have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Posted on Nov 11, 2008
    Novelist:
    Scholar:
  • 111 Answers
HP.com has a web page that you can use to diagnose this particular problem. It contains several links to help you troubleshoot, depending on what the cause may be:
Color Printing Problems
Hopefully, this will help. Good luck and post back your results.
It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
Jan 16, 2010 | Apple HP DeskJet 840c InkJet Printer
I hooked up my HP Deskjet 812C seems like there is no power?
HTML clipboardHi,
It may sound silly but have you had your printer unused for a while?
If so the inks C6615A [No. 15] black and C1823A color ink cartridge may have clogged up?
The empty weights are 65g and 90g anything over that...
1g = 1ml of unused ink
If you still have ink you can unclog them with a HTML clipboard Magic Inkjet Flush Kit which is great if you ever need to UNCLOG an HP Canon Epson or any other inkjet printer.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Oct 29, 2009 | HP DeskJet 812c InkJet Printer
Printer is only printing pinks. Just changed ink
Try cleaning the print head. Do this under the tools for the 812c (do not physically clean). You may have to run the clean utility as much as 5 times.
Aug 17, 2009 | HP DeskJet 812c InkJet Printer
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
New color cartridge won't print in correct color
Was this a new factory ink cartridge or a refilled one?
I have seen some reconditioned/refilled with the color inks refilled in the
wrong section.
Sep 25, 2008 | HP DeskJet 812c InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Colored text printing
The printer assumes that the color cartridge is good, and is trying to print with the dead color cartridge.
See if there is a setting for your printer under the control panel, printer, and go to printer properties.
See if you can select to print BLACK only.
I know they have this option for some Canon Printers, but not sure with the HP Printer Drivers.
Worst case senerio, Highlight all of the text, and change the color to BLACK before printing. You can always just pick up a cheap refilled cartridge at Staples since it wont be used a lot, the quality isnt going to make much difference.
Good luck.
Hope this helps.
Mac
Feb 08, 2008 | HP DeskJet 812c InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP DeskJet 812c InkJet Printer Logo
343 people viewed this question
Ben Johnson
