Question about Ricoh FAX5000L Plain Paper Laser
Need assistance in entering service mode on a Ricoh Fax 5510 to reset fuser error. Have service manual, procedure in there does not seem to permit access. Do you have someone who can talk me through this. I am a printer tech.
  • Univac120 Nov 13, 2008
    My rating was based on the fact that I precisely stated that I was seeking information of how to enter SERVICE MODE in order to reset a fuser malfunction error code. The advice presented was for reseting a user error which would occur upon the expiration of a fuser. Thus the advice provided was inapproriate for the requested problem. Now, the problem is that this printer has a 544 fuser error, which was defective, and the fuser has been replaced. however, the machine will not function until the SERVICE ERROR is reset, which must be done in SERVICE MODE. Thus my query, how to enter SERVICE MODE to reset the error. By the way, I have the service manual and the procedure for entering service mode is not clear to me and I need assistance. Thank you in advance for your help.
    Genius:
  • 2,120 Answers
Do you need to reset the maintenance count or clear a service error.
If it's a maint. count it's USER TOOLS #
Posted on Nov 11, 2008
  • 1 more comment
  • Leroy Elliott
    Leroy Elliott Nov 13, 2008
    Why did you rate this inapproriate?
  • Leroy Elliott
    It's on page ID 10 T
  • wizard693 Dec 29, 2010
    How do you reset the ADF maintenace kit message
RICOH AFICIO SP 4210N SERVICE MODE SC 545 Power Off On How Solve it this error?
SC545 fusing lamp remains on. reset fuser error in service mode. If it still reoccurs. Possible bad thermistor or power supply board. To go to service mode press up and down botton for about 5 sec and then press enter. In service mode engine fuser reset SP5810 execute
Sep 30, 2017 | Ricoh Office Equipment & Supplies
HOW TO RESOLVE C8 ERROR IN RICOH SP 111 PRINTER
Ricoh SP 111 with C8 Error:
The C8 is a fuser error. As a safety feature, the machine will be disabled (to prevent fire and what not.. )
The service manual says that SC542 is caused by a too low fuser temperature, after 5 readings.
Since the hot roller was 5°C below the reload
(operating) temperature the fusing thermistor is deformed or out of position or full of gunk (toner residue). Or there may be a piece of paper between the sensor and the hot roller.
The fusing lamp harness can also bee loose, broken or defective.
The fusing unit can be defective
After servicing the machine to solve the problem, the service
technician must execute a "Fuser SC Reset". Otherwise, the machine
will continue to issue this SC code and cannot be operated.
Executing Fuser SC Reset
1. After correcting the problem, open Smart Organizing Monitor.
2. Enter the service mode to display the Service Mode screen.
3. On the Service Mode screen, click [Fuser SC Reset]. This releases the fatal fusing error
which locks the machine.
4. Select "On" for Fuser SC Detect. This setting shuts down the machine if three successive
paper jams occur in the fusing unit.
Jul 27, 2017 | Ricoh Office Equipment & Supplies
Sir ricoh sp310dn sc543 error /but 2 key no display
This is related to SP311 models.
Execute "Fuser SC Reset" to recover the machine after completing the
recovery procedure. Otherwise, the machine continues to issue this SC
Fusing related SCs
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter the "Engine Maintenance" in the "Maintenance mode".
Press "Execute" in "Fuser SC Reset" with engine maintenance mode, and then turn the main
power switch off and on.
Mar 23, 2017 | Ricoh Office Equipment & Supplies
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Sc544 on ricoh 1075
You have a fuser error, you will need to repair the fuser unit or replace it, can be the thermistors, thermalfuse or heat lamp, then you'll need to reset the machine via service mode, strongly recommend to be repaired by a technician. Good luck.
Jan 06, 2011 | Ricoh Office Equipment & Supplies
Ricoh Fax 3700L
Fuser error.....Either blown fuse, bad thermistor, or blown lamp. Problem needs to be repaired, and then a WAY over complicated reset procedure has to be performed in service mode to clear the error.
Apr 28, 2009 | Ricoh Office Equipment & Supplies
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
In order to clear error SC542, you must perform procedure 5810.
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Ricoh service mode to reset
This is the solution from Ricoh website:
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
I'm told this works as well...
On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
Jul 09, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh FAX5000L Plain Paper Laser Logo
502 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
