Question about Cameras
Battery keeps going flat - Cameras
  • 104 Answers
Turn off all options - clock etc. contact factory - this is not right- sony? Gad recalll for this
Posted on Nov 11, 2008
Nextbook area 8 keeps dying saying low battery. I plug it in battery level is great. How do I fix it
is the battery overheating
try to make the battery go flat flat then recharge
if nothing works
would suggest a new battery for it
Apr 16, 2017 | Nextbook Tablets & eReaders
My battery on my iphone runs out in 2 to 3 hours. What to do?
I think you must check your charger and if ok replace your battery
Mar 31, 2008 | Cell Phones
Tip
Mobile phone battery not holding charge and going flat to quick
hi, now this is a very common problem the only thing you can try is to let the battery go totally flat and keep switching it on untill the phone wont even light up.
Then what you need to do is give it a full charge for at least 8 hours this may lengthen the time your battery takes to go flat.
Now what the shop should have told you and didnt and what they should tell you in the owner's manual and dont is that once a month you are supposed to let the battery go totally flat and then do full recharge.
Doing this will ensure you get maximum time out of the battery and it makes the battery last at lot longer before you need to replace the battery.
If after doing this your battery only last an hour or two then the chances are the battery needs replacing so if you do this just remember to let it go flat at least once a month as the battery never does a full charge due to the fact that the battery never goes totally flat so this then causes bad cells in the battery so follow those rules and your battery will last longer than normal
on Dec 03, 2009 | Cell Phones
Renault 19 1992 diesel battery keeps going flat
Could be your alternator is bad,belt is loose,Autozone will test for free,also check the fusible link at positive battery cable,could be burnt or melted.,
Nov 23, 2012 | Cars & Trucks
Car keeps flatening batterry light and indorcators wont work either
battery may be flat. You can check that with a multimeter.
Next check the alternator. Faulty alternator leads to uncharged battery.
Sep 11, 2012 | 2001 Alfa Romeo 147
My car battery keeps going flat ive brought a new battery and had the alternator replaced and yet my car keeps going flat
you have a battery drain somewhere, if you can use a multimeter disconnect the battery and hook it up in line set up as a ammeter. make sure nothing is on in the car and it will tell you how much power is nbeing drawn. start by pulling fuses and relays out to figure out what circuit the drain os on. eg, glove box light, amp wiring. ect
Jul 06, 2012 | 1996 Mazda Familia
Battery going flat on car daewoo leganza 1997
hi for a battery to go flat means your altenator isn't doing its job in charging it. all cars are different but it has to charge at a certain rate in order to keep it going. if the charge rate is very low then yes the battery wont last. if alternator is ok then possibly a wirring fault somewhere.
Dec 23, 2008 | Daewoo Leganza Cars & Trucks
Cameras Logo
70 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
