Question about Whirlpool LER4634J Electric Dryer
Start /stop problems
The belt went out on our dryer so i replaced it.... Now when i try to start it... the on/off light will come on, but when i push the start button the dryer will either do nothing.... beep a short beep and do nothing or it will beep normally come on and the drum will rotate about half a turn and then shut off... or it will come on and run for about 5 minutes and then shut off..and it acts this way whether the dry is warm hot or cold.....any ideas??
    Scholar:
  • 66 Answers
It sounds like this could be a door switch problem. When you removed the front panel, you had to unplug the door switch. The door switch could be loose or one of the wires you had to reconnect is loose. Another thought is that the drum isn`t lined up correctly with the front panel and the rear of the dryer housing.
Posted on Nov 11, 2008
    Sergeant:
    Champion:
  • 324 Answers
Check to make sure you have the belt routed the right way around the idler pulley.
Dryer Won't Start
Cam,
One thing you can check on if the circuit breaker is okay is to see if the drum turns freely. If the belt is still intact, you should have some resistance to turning the drum by hand. Many dryers have a safety in them that if the belt breaks the dryer will stop and not restart until the belt has been replaced. Hope this helps!
Nov 10, 2014 | Dryers
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
My maytag dryer model LDE7304ADE stopped working. I stopped it mid-way through, closed the door, pushed the "on" button and it made a weird noise. I tried again and now it doesn't make any...
Door switch broke???
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Dryers
Dryer will not start upon pushing the start button.
the motor is more than likely bad but just to be safe check the blower wheel and make sure there is not anything in it then remove the belt and try to turn motor if the motor feels real tight then you need to replace the motor
Sep 18, 2009 | Kenmore 63942 Dryer
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer won't turn
The problem is likely a slipping dryer belt. The belt tensioner is not working or the belt needs replacing.
Apr 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
