Question about HP ProLiant DL100 (367988PR2) 160 GB
Can see physical drives, but not logical
Drives were seen and I was installing server 2003. I had to abort because key was not working. Found a new server 2003 CD with license but when it starts to load it cannot find drives now.
    Problem Solver:
  • 8 Answers
Are the drives on a Raid controller, or an unsupported disk controller?
For the HP Proliants, you can use the supplied cd's that came with the server. The SmartStart CD guides you through the install process and will prepare storage, driver installation, preinstallation etc for you.
That way, you don't have to worry about creating disk sets etc for the storage card, network, ...
Posted on Nov 13, 2008
I am having a problem with my dell poweredge 1800, it beeping continuous
Assuming this is still an issue...old as it is...
You need to boot the server and press the correct prompt to enter the BIOS of your PERC RAID controller. There you need to manage your physical/logical volumes.
Chances are that either you had a drive failure or the metadata on your RAID volume (JBOD?) was corrupted. This is a common issue with these LSI-based PERC[5-6]i RAID controllers that Dell utilized.
Jan 18, 2014 | Dell PowerEdge 1800 Server
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
ServerRAID-6i Logical drv =1, Others=0 Firmware7.12.13,Status OK Warning:1 Logical drive(s) Offline Warning:1 Online drive(s) defunct
HI, It appears you may have a failed "physical" drive in your Raid set on the server. The system will run fine with one failed drive, but it is recommended to have the drive replaced by it's vendor, or vendor representative. If the 2nd drive in your raid set fails. You will loose your logical drive and all your data on this drive.
You may wish to confirm you have successful, recent backups, just in case another disk fails before your failed drive has been replaced.
Oct 13, 2010 | IBM xSeries 226 Server
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Physical drives not found
I"t says one logical drive is offline and two physical drives are defunct."
sounds like RAID. Try booting up off of one drive. If there is no OS, try keeping one drive in the drive bay and see if you get a orange light then. like dereknewland said, could be the backplane.
Mar 11, 2009 | IBM eServer xSeries 346
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Perfdisk problem
try typing this at a command prompt and reboot
diskperf -y
DISKPERF [-Y[D|V] | -N[D|V]] [\\computername]
-Y Sets the system to start all disk performance counters when the system is restarted.
-YD Enables the disk performance counters for physical drives when the system is restarted.
-YV Enables the disk performance counters for logical drives or storage volumes when the system is restarted.
-N Sets the system to disable all disk performance counters when the system is restarted.
-ND Disables the disk performance counters for physical drives.
-NV Disables the disk performance counters for logical drives.
Nov 06, 2007 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
