Question about Compaq Armada 4220T Notebook
Invaled sytems disk
I got a amrada 4220T when i got it it worked fine it had windos 98 on it i tryed to put xp on it and did not have space to finish when i restared my laptop it started asking me for the oriangel systems disk . but my laptop dose not have a cd rom or flopy drive.
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
FYI,
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
Emonster 550 wont load operating system wont read disk nothing can you help me please?
Go into the BIOS (watch your POST screen as you turn the computer on for instructions if you don't know how to get in there, it will say something like "press F2 to enter setup") and set your computer to boot from your CD drive. Put your restore or XP disk in the CD drive and reboot.
May 17, 2009 | Dell Computers & Internet
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
Disk epac
try disk checking utility and check for Temp files try cleaning them or Google CCCleaner download it its free and try to find the files that are taking space delete them , other wise go to control panel in system see how much system restore has reserved on hard disk for itself try redusing the percentage , Defragment ur hard disk using Xp disk checking utility lemme know abt it
Nov 07, 2008 | HP Compaq nx7010 Notebook
Windows 98 SE
if you need an operating system and would not mind using linux (an alternative to windows) look on the www.puppylinux.com site and see if you would like to try it. the download is about 80meg and it runs very fast on all the computers i have used it with. or try looking on softpedia for a free download of the outdated windows xp install disks. or you can buy some disks from ebay. but i reccomend trying puppy linux, it is free and you have nothing to lose.(the disk is a live boot disk, so it should just run off the cd)
Jun 03, 2008 | Microsoft Windows 98 Second Edition for PC
I have a ---HP Pavilon media center M 7640 n desktop PC Problem: I get only Window error recovery A click to Start Windown Norally. I donot like to use my sytem recovery discs ts there any other way to...
if you use windows 98 you can put in a start up disk and have it scandisk to fit it. try to run windows norally. sound like a hard drive problem, you can get windows cd's on ebay cheep. XP home is chepest.
May 19, 2008 | HP Computers & Internet
DISC SPACE
The problem may be that you have too much space (sounds dumb I know) Windows 95/98 originally did not support drives as big as we have now, resize your drive down to less than 2GB and retry the install, or create a partition for the Game that si smaller. If you are running XP/Vista, you may be able to resize with disk Management, otherwise there is third party software like Partition Magic...
I hope this helped.
Dec 06, 2007 | Computers & Internet
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Compaq Armada 4220T Notebook Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
