SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
SOURCE: Kenwood KDC-X590 ipod
Do you have a Ipod shuffle?
Is the deck on random?/shuffle?
Try pressing the small reset button on the deck, its small a small black button you would need a pencil tip to reset!
Hope it helps,
Don
SOURCE: Kenwood KDC-MP628 unlock code
press the auto and track up, on the face at the same time. The four digit line should go away, then use your remote and enter yout code
The code is 5227
press the numebers: 5 (two times) then press the track up key
2 (three times) then track up
2 (1 time) and track up
7 (two times) track up key again
SOURCE: need the wiring schematics
http://www.sirius.com/pdf/manuals/KCA-SR50.pdf
find it here in this manual
SOURCE: i lost the wiring color codes for my kenwood KDC-MP628 CDReciever
http://www.tehnomagazin.com/Auto-radio-car-connector/KENWOOD-Car-Radio-Wiring-Connector.htm for the deck
1) Remove the ashtray and the two outermost screws exposed in the ashtray cavity.
2) Remove two screws from each side of the dash console.
3) Remove the climate control knobs.
4) Unclip the trim bezel and remove.
5) Remove four screws securing the car stereo to the dash.
6) Pull car stereo from console releasing antenna and connectors.
Constant 12V+
Red
Switched 12V+
Orange/Yellow
Ground
Black
Illumination
Red/Green
Dimmer
Green/Red
Antenna
Driver's Pillar
Front Speakers
6 1/2" Doors
Left Front (+)
Orange
Left Front (-)
Black
Right Front (+)
Gray
Right Front (-)
Green
Rear Speakers
4" Tail Gate
Left Rear (+)
White
Left Rear (-)
Red
Right Rear (+)
Yellow
Right Rear (-)
Blue
