Question about Xerox Phaser 7750DN Laser Printer
I can't print full bleed from CS3 to a Phaser 7750DN
I'm trying to print a full bleed 8.5x11 document from InDesign and the printer crops the image to about .25 of an inch on three sides and a little more than half an inch on the other side. My settings in InDesign are 0 margins and print full bleed. I also testing from a full bleed Word doc, PDF, and Photoshop file and got the same results.
Anyone know how to fix this so I can print a full bleed? I can't figure out if it's the printers options or if maybe there's some settting on my computer that is making this happen. I'm running a Mac with 10.5.5.
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Posted on Nov 12, 2008
7500 dt to print full-bleed
This printer is not capable of printing full bleed. You will have to print on oversized paper and trim it to get dull bleed.
Jan 10, 2014 | Xerox Phaser 7750 Laser Printer
Can i reset the imaging unit on my phaser 7750
There is a chip in the bottom of the image unit which stores the image unit life. These can be reset but it requires special hardware and software to do it. You can also buy replacement chips, they're usually about $50 for a 4 pack and you can find them on e-bay. Rechipping with out replacing the entire image unit will result in lower quality prints though.
Aug 09, 2011 | Xerox Phaser 7750DN Laser Printer
My Phaser 7700 Printer does not come to a ?Ready? state
This might be a bad main Image Processor (650-4307-00) board. We can isolate it by printing an internal test print.
You can power up the unit in diags (hold "back" & "info" buttons while powering up) Go to "Built in Test Prints" and try to print the "Grid 1 Dot Pattern"
If you print, then it's proven...
If not, then you will get an error that will allow further troubleshooting.
-Whit
May 10, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox 7760 GX squishing print jobs vertically
you need a snippet {software patch installed}call .xerox support
Mar 13, 2009 | Xerox Phaser 7750GX Laser Printer
Image enlarging when plating!
hi pip,
check your mac properties, if it is a PC powerchip, you may have to enable "Rosetta" in the indesign applications properties folder.
this may resolve the file print size conversion process.
Rosetta is inbuilt in mac with this type of powerchip, and when activated, works in the background..
http://www.apple.com/rosetta/ this link will give u an insight
not sure this is your answer....cheers rooboy
Dec 08, 2008 | Xante PLATEMAKER 4 Laser Printer
Distorted image printing from InDesign to Xerox Phaser 8560
Have you tried a different driver? Most of those phaser printers have a PS driver loaded, See if there are PCL drvers for that product, and try that. I went on the Xerox.com site and they have both PS and PCL 6 and PCL 5 drivers, I believe one of those will help your problem.
Now that being said, If you are getting the stretching on other programs, then the problem is the drum motor encoder is getting contaminated with silicon lubricant from the maintenance kit. That will cause that problem, But since you are saying it is with one specific program, I suspect a different driver will correct the problem.
Sep 26, 2008 | Xerox Phaser 8500/DN Printer
Printing from Indesign CS3 to Epson CX11NF problem
hi-
Actually what i can suggest is that for you to try printing from a different application, such as microsoft word or paint. try printng a landscape image. now if its going to print it correctly call adobe since that might be an application issue. thanks for using fixya!!
May 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
594 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
