Question about Ricoh Aficio 1013F Copier
Faxing instructions I have an Aficio 1013f, it has the fax features, but I do not know the steps to send one out. Please help. I have looked at the manual and it does not have anything about the faxing.
  • 58 Answers
Or for memory send, press fax button, dial fax number and then press the green start button
Posted on Dec 16, 2008
Press fax button. on hook dial, number with the keyboard, place the original on the cristal, pres start, after all pages has been scanned press # or take the phone, place original, mark the number on the phone when you hear the signal press start.
Posted on Nov 12, 2008
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
RIcoh Aficio 2045,turn off fax delivery report
download the manual from the www.ricoh-usa.com web site for the fax advanced features.
Refer to page50, from the pdf numbering.
Or at page147, from the document it self numbering.
Here is a link for quick find:http://www.ricoh-usa.com/downloads/manuals/bw/aficio2035/manuals/FaxAdvancedFeatures_PartII.pdf
Jan 21, 2010 | Office Equipment & Supplies
Fax header Ricoh 1013F
GEEZ, the 1013f, I beleive you have to access the user tools buttom, it is on the left side of the control panel. From there slect fax features, then select general/settins adjust, then program fax information, then slect fax header, from there you will use th alpha keys on the left side that double as the one touch keys. When you are done select ok!
http://copierquestions.websitetoolbox.com/
Aug 13, 2009 | Ricoh Aficio 1013F Copier
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
Apr 01, 2009 | Ricoh Aficio 1013F Copier
Ricoh 1013F Fax Line answering phone calls
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Mar 09, 2009 | Ricoh Aficio 1013F Copier
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
Changing the number of rings on fax.
Press the "User Tools/Counter" button at the control panel.
Under the display, press the "Right Arrow" button until the display shows "4. Fax Features" & press the "OK" button
Press the "Right Arrow" button until you display "3. Setup" & press "OK".
Press the "Right Arrow" button until you display "5. No of Rings" & press "OK"
Enter # of rings with numeric keypad & press "OK"
Display will briefly show "Programmed"
Press "User Tools/Counter" button to exit back to regular display
Jul 08, 2008 | Ricoh Aficio 1013F Copier
Ricoh fax/copy machine
Instructions for 1013F are as follows:
above the blue numeric keys 2/3 there is a button with a small box with 123 in it this takes you in and brings you out of the USER TOOLS MENU.
Press user tool button once...user menu on display
use right arrow key...press3x..Fax Feature..press ok
right arrow2x..ok
again right arrow2x.ok....DATE/TIME on disply .ok
change then ok it once done exit by the 1st button you started with...USER TOOL BUTTON. all the best....
Mar 28, 2008 | Ricoh Aficio 1013F Copier
164 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
