Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Lowering ringer volume on handset v tech 5.8 digital phone
I lower the volume of the ringer as it is too loud. i can lower the volume while it is ringing, but it doesnt stay lowerered aftyer i end the call. next call the ringer is loud again. the base ringer stays low. just the handset is too loud. v tech 5.8 digital phone
  • Anonymous Mar 16, 2014
    RINGER VOLUME TOO LOW WITH INCOMMING CALLS HOW TO INCREASE VOLUME
  • 689 Answers
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
  • Peter D
    Peter D Nov 11, 2013
    This doesn\'t work, I manually set the ring volume to the lowest setting as as not to wake the baby, but on the next inbound call, the ringer is at full volume again! But when i check it on the handset, its low! These phones are the garbage!
Lower ringer volume
The procedure varies from model to model. Since you neglected to specify the model of your VTech 5.8GHz phone I can only suggest you enter it into the search box here to download a copy of the manual.
May 30, 2012 | Vtech V-Tech 5.8 Digital Spread Spectrum...
How to lower ringer volume for NEC DTR-1-1 Corded Phone
1. c:%5cusers%5ctarich%7e1%5cappdata%5clocal%5ctemp%5cmsohtmlclip1%5c01%5cclip_image001.pngPress the ^ or v button toincrease volume while on a call2. c:%5cusers%5ctarich%7e1%5cappdata%5clocal%5ctemp%5cmsohtmlclip1%5c01%5cclip_image002.pngSelecting ring pitch and ring volume Pickup handset Pressprogram button Dial# Dial0-9 RINGING VOLUME SOFT MEDIUM LOUD RINGING TONE PITCH SLOW 1 2 3 MEDIUM 4 5 6 FAST 7 8 9 OFF b> 0 b> b> b> b>
Jun 30, 2011 | NEC DTR-1-1 Corded Phone
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Thank you for using FixYa.
Have a great day.
Jas247
May 17, 2011 | Vtech Cordless 6041 Phone
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
EnV3 Ringer Volume TOO LOUD
There is a bug with this phone. All of them do this. The V05 firmware that came out 10-2-09 does not fix this. Sorry. I hate this too.
Oct 06, 2009 | LG enV3 VX9200 Cell Phone
Loud feedback when All-Page. Lower speaker volume does not fix.
We have the same phones in our office. The feedback happens with our phones if the handset is left on the base. Picking up the handset and speaking through it as if your are on a phone call during the page should solve the problem of the feedback. If not, you may want to look at your P.A. system settings.
Apr 09, 2009 | Panasonic KX-T7633 Corded Phone
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Jan 02, 2008 | GE Cordless Phone 900 MHz
the ringer is too loud and the beeps from pressing the buttons are too loud.
Dec 30, 2007 | GE 25932 Cordless Phone
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
4,183 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
