Question about HP Computers & Internet
I think I have a virs problem I can not find my device manager detail nor can I find my wireless network icon in my network files
    Sergeant:
    Champion:
  • 275 Answers
Is the device manager totally blank ?
and what do u mean by wireless network ? what exactly u are doing plz be clear
Posted on Nov 11, 2008
Compaq presario v2000 wireless card not showing up in device manager
In Device Manager click the tiny arrow beside Network Adapters. This where the wireless card should be listed.
Next, locate the row of small icons just below the View tab at the top of Device Manager window.. Click the icon on the right "Scan for Hardware Changes".
Check again under Network Adapters to see if the wireless card is listed.
Or, check for any yellow exclamation marks in Device Manager list. An item might be named Unknown Device. Double-click it and select Update Driver.
Jul 01, 2014 | Compaq Presario 700 470024-192 Notebook
Deleted some files from toshiba laptop and now I cannot connect to the internet
Try This:
Windows XP
Accessing Device Manager using Control Panel 1] Press the Start button. 2] Go to Settings, a new menu will pop out to the right. 3] Click on Control Panel. 4] When the control panel comes up, find the System icon and open it up. 5] When the System properties box opens, click on the Hardware tab. 6] You should see your 'Device Manager' button here. Click It.Expand your 'Network Adaptors' from this list, as shown below, using the [+] box.
Now locate your Wireless device, right-click it and select uninstall.
**If prompted, DO NOT uninstall your drivers also**
Now right-click your machine name at the top (I have blacked mine out in the above image for obvious reasons) and select the 'Scan For Hardware Changes' option from the menu.
Let it settle, reboot.
Windows Vista &Windows 7
Start>Right click Computer>Manage>Device Manager
Complete the steps from above to locate and uninstall Network Adaptor.
Jul 31, 2012 | Toshiba Satellite L305 Wireless Card...
Wireless card not working ze4933
f you suddenly have a problem with your network connection, before you make any changes, you must determine whether you have a problem with (1) the wireless device on the computer, (2) the connection between the computer and the network , or (3) the connection from the ISP provider to the network. Each of these devices / connections must be operating independently before they can all work together.
  1. View the wireless icons in the system tray to determine the status of the devices and connections. Then, open the appropriate utilities for detailed information on potential problems. The detailed windows are: the Windows Wireless Network Connection, the HP Wireless Assistant, and the Device Manager.
  2. When you have the detailed information, identify the specific type of connection problem by reading the connection description statements below. Then select the statement that most closely describes your problem for a detailed explanation of the corrective actions.Internal wireless networking adapters or PCMCIA cards may have problems connecting to a wireless network if the Advanced options are not set properly. For instance, some PCMCIA devices can adjust the power output to increase the strength of the wireless signal.note.pngNOTE:If the computer and router are in the same physical area, you may want to reduce the signal strength to save battery. However, if they are not located near to each other, you can turn the power up to 100% to maximize the signal.Most HP internal wireless cards can be set to turn off to save battery power. If the wireless connection was working but suddenly stopped when using the battery, the card may be turning itself off exactly as planned. You can use the Device Manager to specify the power settings and keep the wireless card turned on.To verify and change the wireless device settings in the Device Manager, do the following actions.
    1. Click Start , Control Panel , System , Hardware , and then Device Manager .
    2. Click the plus sign (+) next to Network Adapters . If multiple devices are listed, you should check the devices one at a time.
    3. Right-click on the network adapter, and select Properties .Select the Power Management tab, if available, and verify the power settings. Not all wireless device drivers have a Power Management option.
    When you have set the Power Management options, close the Device Manager, restart the computer, and attempt to reconnect to the wireless network.
Sep 21, 2011 | HEWLETT-PACKARD Pavilion ZE4933 Laptop...
I cannot connect to my wireless network ( I can connect ONLY by wire) and my Internet provider suggested me to try and find a new driver. Can you find one and notify me?
I think it would be better if you check first the Switch of your wireless and see if its turn ON. If happens that the switch is ON, you have to check the Device Manager on your machine and see if the wireless card is listed under Network Adapter. Here's how you can check the wireless card.
Windows 7 and Windows Vista
Start->Control Panel->Hardware and Sound->Device Manager (in Category View)
Start->Control Panel->Device Manager (in Large or Small Icon View and for Vista Classic View)
Windows XP
Start->Right Click on My Computer->Properties(it will open a window)->Click Hardware->Device Manager
Under Device Manager just double click on the Network Adapter and it should give you list, just check if your Wireless Card is listed, if its not most likely the card is not working or faulty. It would be better to call the manufacturer for more assistance.
Apr 15, 2011 | Computers & Internet
Wireless network
Troubleshoot a Compaq Wireless Network Card
step 1
Open the Compaq's "Start" menu and type "Device Manager" in the "Search" box. Click the "Device Manager" icon.
step 2
Scroll down to the "Network Adapters" heading and click the plus sign to expand the list of attached network adapters. Right-click the name of your computer's wireless network card and choose "Uninstall." Follow the uninstall prompts on the screen.
step 3
Close the "Device Manager" window and return to the "Start" menu. Click "Restart" and wait for the operating system to boot up again. Follow the "Found New Hardware" prompt that loads on the screen to reinstall the network card.
step 4
Return to the "Device Manager" window and right-click the network card's entry again. Choose "Update Device Driver." Follow the prompts to install the latest driver.
step 5
Check the left side of your Compaq computer if you are using a laptop to see if it has a wireless network switch. Push the switch over to the "On" setting if it is set to "Off."
step 6
Open the "Start" menu and click "Network." Select the "Network and Sharing Center" icon at the top of the window.
step 7
Click the red "X" icon to have Windows automatically search for the problem. Follow the prompts to diagnose and resolve the network connection issue.
step 8
Double-click the networking icon in the system tray at the lower, right corner of the screen and click the name of the network you need to connect to if you are using Windows 7. In Windows Vista, instead click "Connect To" in the "Start" menu and click the name of the network.
Setup home Wireless Network
Dec 07, 2010 | Compaq Presario 700 470024-192 Notebook
My Netgear WG111v3 adaptor was working yesterday but now my pc does not recognise it and it says that it has malfunctioned. i have reinstalled all software and also installed the latest software from...
Make sure you have downloaded and extracted the correct driver for your OS have a read here http://kb.netgear.com/app/answers/detail/a_id/12962 about halfway down the page is an orange icon to download the file
I would remove the wireless adapter from the device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc this brings up device manager, look for the network adapters and click onthe + sign Is you network adapter listed or does it have a X or ! or ? against it If listed I would right click onit and uninstall. ---- Now reboot the PC - it will detect new hardware, and start to install the wireless adapter, it should now automatically find the driver as you have already installed the driver software. But if it does not then when asked browse to the extraction files you created from the website If you have a ? against the device its looking for the device driver - right click and install and then browse to the files you extracted
Mar 20, 2010 | 2wire Computers & Internet
I can't activate my internal wireless card my laptop is dell latitude D800 helpp please!!!!!!!! xxxx
Try going to your control panel, click on system, open the system propertie's, in the system propertie's box click on the hardware tab, under hardware click on device manager, in the device manager find network adapter's, click the + next to adapter's, right click on the wireless network adapter then left click on propertie's, in the wirelss network adapter propertie's box check to see if it's enabled, in the device status window it should say this device is working properly, if it's still not working try using the troubleshoot tab to resolve the problem, or you may need use the wireless network setup wizard.
Apr 17, 2009 | Dell Inspiron 6000 Notebook
Wireless Connecion Help Wont Show
check in device manager to see if its enabled and have drivers installed.some wifi are installed without a wireless manager and connect to first available(strongest)network.
go into control panel ,administrative tools,sevices and scroll down to wireless zero config and start.
then when you click on wireless icon you will have choices of connections(AP'S)(access points)
Jan 12, 2009 | HP Pavilion dv1000 Notebook
NETWORK ADAPTER PROBLEMS FOR HP LAPTOP
go into device manager click on wireless device and update drivers or in device manager delete wireless device and restart.
on restart sysstem will detect and install found device(wireless)
you may have to reconfigure so check ip address,dns and gateway details first (find them by clicking on your wireless icon and select properties,scroll to internet protocol.select it get details.
Jan 10, 2009 | HP Pavilion dv6000z Notebook
Wireless trouble
Please try to check if the wireless adapter is listed on the DEVICE MANAGER.
WinXP
Please click the START button, then click CONTROL PANEL. Click the PERFORMANCE AND MAINTENANCE icon, then click the SYSTEM icon. Click the HARDWARE tab. Click the DEVICE MANAGER button.
And look for the wireless adapter
And for Vista you can check the site below.
http://www.home-network-help.com/network-or-wireless-adapter-driver-status.html
Feb 27, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
