Question about Sebo X4 Bagged Upright Vacuum
How do I change the flilter on the sebo upright
I can't get the old one out
  • 328 Answers
Depends on the filter you're talking about:
The first filter is in the bag area- unhook and lift off the bin door, then bend down and flick your finger onto the left hand spring that locks the long cylindrical felt filter in place and lift upwards - this will loosen and unlock the filter from the base - put your hand at the back or front of the filter at the front near the base and pull towards you - the filter should then slide off easily.
Or it could be the motor filter you are referring to; push the pedal all the way down on the pedal release to put the X1/X1.1/X4/X5 into the lay-flat cleaning position, and push back the grille on top of the hood - you'll see a push finger mechanism there of which the grille will then be unlocked and can be picked up.
Posted on Nov 18, 2008
HOW DO I GET INTO THE HANDLE TO REPLACE THE FLEX
Check out the video on You tube that shows you how to change the cord on a SEBO upright.
May 23, 2014 | Sebo X4 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo squealing
Just spend all afternoon working this one out. Take the upright section away from the bottom by pressing the release button at the bottom of the upright section. You will see two pipes. One pipe has a grill on the top. That is the problem. Mine was slightly loose which may have caused the whistling or it may not have been making a good seal with the upright section. Anyway, I took it off altogether and the noise has gone
Feb 22, 2013 | Sebo X5 Extra Bagged Upright Vacuum
I need a new set of instructions for my sebo x4 extra upright cleaner
you will have to call sebo or the dealer you brought it from to get manual
Aug 27, 2010 | Sebo X4 Extra Bagged Upright Vacuum
Sebo X4 is squealing when pulled back. Takes a while after it's been running for this to happen. We changed the roller brush (needed it anyway) but didn't take care of the noise. Could the wheels be...
Yep - we think Sebos are pretty good too. I work at a Sebo sales and repair dealership! The wheels are a good bet - I can't think of anything else that might cause the noise. If in doubt, I suppose you could simply wheel one around for a while when switched off...
Feb 15, 2010 | Sebo X4 Bagged Upright Vacuum
Can you help me change the Sensor in my Sebo Auto X-1
do you still need help with this, or has the moment passed? If you still want help, please state why you think the sensor needs changing.
Nov 17, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo vacuum cleaner cuts out ?why
it might be the bag.just check with your local vacuum store
Jun 04, 2009 | Sebo X4 Bagged Upright Vacuum
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
223 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Andrew Taylor
Andrew Taylor
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
