Question about SanDisk Sansa e260 MP3 Player
How do I load pictures from my pc to sansa e260?
I can load songs just fine, but pictures are not being d. Do I need to resize them?
Thank you.
:0) Trevor
  • 1 more comment
  • kraftymommas Nov 14, 2008
    Thank you so much!!! The solution worked and I am now able to show off my pictures on my Sansa!!!
    Thanks again!!
    :0)
  • Anonymous Feb 07, 2009
    HOW DO I LOAD PICS TO MY SANDISK
  • christangel2 Feb 11, 2009
    it will let me download music fine but i cant download pictures or videos.
  • 35 Answers
For pics and video you must install the program from Sansa called Media Converter.
You can download it here:
http://www.sansa.com/support/sansa_e200/faqs
On the right side of the page under downloads.
Posted on Nov 11, 2008
Can some body help me how to put pictures in my mp3 player sansa e260 i can put music but not pictures and videos
Posted on Oct 30, 2009
Sansa e260 - the mp3's that i load from my pc don't show up.
Try drag and drop from the music folder you have your music in.to the media folder on the sansa use windows explorer.........
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
How do you reformat the sansa E260?
There are several possibilities.
1) The songs that you loaded may not be compatible with the player - iTunes files, for instance.
2) The songs that you downloaded may not have transfer rights - i.e.: they will play fine on a computer, but they will not play on an mp3 player.
The solution to the above two possibilities would be to download songs that are in mp3 format only. They do not have strings, stipulations, headaches, etc. attached to them.
Possibility #3 is that your mp3 player is in the wrong USB Mode. Songs that show up in MSC mode do not show up in MTP mode, and vice versa. To change this, go into your Sansa player's settings menu and change the USB Mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Problem recognizing songs in sansa e260 mp3 player.
From what I'm hearing you don't have a good driver. If you still have the disk use that. If not google it or something. I have a Sansa e260 as well so I would suggest loading the songs on in windows media player rather that windows explorer. If you open Media Player and then go to sync and it does not recognize your device, then you have a bad driver. If not, then start syncing your songs that way.
Hope everything works,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
Deleting songs from my Sansa e260
Disable auto-sync in Windows Media Player - will solve your problem.
Nov 24, 2008 | SanDisk Sansa e250 MP3 Player
Doesn't recognize some songs
change the format of these songs like the other ones.
Sep 28, 2008 | SanDisk Sansa e260 MP3 Player
Erase all songs on my sansa e250R mp3
if you have windows media player try formatting it...that will automatically delete everything so you start all over. hope that works. =)
Apr 14, 2008 | SanDisk Sansa e260 MP3 Player
Sansa mp3 e260
Just close it if you dont want WMP. IF what you mean is i dont know how to download songs then go to The SYNC tab on WMP but first make sure you are using WMP11 or Higher. After clicking the SYnc tab then Drag the song files to the empty spot below the playyers picture and clik The Load Songs button or Synchronize button. Hope this helpsl
Feb 17, 2008 | SanDisk Sansa e260 MP3 Player
Why does this happen to my converter/e260? (pic)
the sansa media converter is only used for videos and pictures.
for song you go to my computer and u will see that it says sansa e260 you click on it then it will have files for music vieos pictures and recoding click on music and drag ur music on to it.
Jan 11, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e260
Do you mean the picture of the album of each song ?
Jun 28, 2007 | SanDisk Sansa e250 MP3 Player
Pink Screen says "No Song"
Hi. It would seem that either the internal memory of your player has been corrupted or the firmware has experienced some errors. The best way to fix your player would be to either format it or re-load its firmware. Either way, you may need to re-load your music files once again. First, you would need to set your player to MSC mode by navigating the menu as follows: Menu >> Settings >> USB Mode, then select "MSC". If you have the "Rhapsody" E200 version, then select "Rhapsody" (it's the same as "MSC" mode) Next, plug your player in your computer and look for the drive letter corresponding to your Sansa. Right-click on the drive letter, then select "Format". Just make sure that the File System is set to FAT32. Click "Start" to begin the Format and follow the on-screen prompts. Since your songs came from audio CD, simply Drag-and-drop the files to your player (MSC mode is will actually work best with audio CD songs) If this does not work, then go ahead and re-load your Firmmware using this instruction I received from SanDisk technical support: Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would restore your player to normal settings.
May 16, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
710 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
