Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Color problem I have flat screen Sony Bravia tv Model KDL-40S2000.I have a problem adjusting the color.I have lost the red hue..
  • spcrafts Apr 13, 2009
    where's the default settings?
    New Friend:
  • 99 Answers
Try loading the default settings
Rifaa
Posted on Nov 20, 2008
Too much purple in sony bravia
Try to examine the screen with the color turned off---is it a uniform color other than gray or black and white?
A photo posted somewhere with a link showing what it looks like might be helpful.
May 15, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL 40 HD
it's in a service test mode. have you unplugged the tv? that should reset the tv..if you still have problems after ..it will need repair.
Sep 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia lcd tv
Are you connected to a cable box or satalite rcvr using compoment outputs (y,pr,pb)? It is posible that the red cable has come loose and picture has no red,causing a mostly blue picture.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
