Copy orientation I have a Canon IR5185 with a colorpass and whenever I put a check on the glass to make a copy, the machine orients the copy to the stadard letter (cutting off the edge). When I turn the check and try it that way, I get the same result. What can I do?
  • 1,326 Answers
Basicly, the check is smaller then a standard LTR size paper. The copier will only see it as a standard size. You will have to put a standard size peice of paper behind that check on the glass so it will read a standard size of paper.... The copier will not know that you are coping a check... They are not that smart..... Good Luck
Posted on Nov 12, 2008
Flashing printing,please wait
Clear your print que,check that the paper orientation is correct,if it will make a copy then machine is functioning correctly. If it wont you have a heat issue so its in a constant wait process. After some time the machine will E code.E000,E0001 etc. If all else fails rest set both computer and machine.
Apr 04, 2014 | Canon Office Equipment & Supplies
Copier orientation is incorrect. We print or copy something "portrait" and the result is "landscape"
Check to make sure that the paper size/ orientation dial is correct for the paper in the paper cassette.
May 02, 2011 | Canon imageRUNNER C3220 Color Copier
The machine keeps changing the orientation when you place the papers to be copied on the glass. how can you pick the one you want?
enter additional function(*); on screen, select copy settings>auto orientation> off>ok.
switch off the machine and re start.
place original according to the orientation of paper in paper tray and make copies.
Feb 08, 2011 | Canon ImageRUNNER 3235 Black and White...
Our Canon imageRUNNER 2270 is incorrectly orienting the paper. How do we fix it?
You can turn off the Auto Orientation of the machine. Go to Additional Functions > Copy Settings > Auto Orientation > On/Off
Oct 27, 2010 | Canon imageRUNNER 2270 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Canon MX850 printer - ADF copy has black line on it
Hello, my name is Steve,.
This is a common problem and an easy fix.
If you lift the ADF / top cover assembly up, you will see a small narrow piece of glass next to the flat-bed glass.
Ths is called a "Slit-glass". The only purpose is to read content from that point by the scanner, The Scanner will sit in the underside of it.
It is dirty. Wipe this with glass cleaner and a soft lint-free cloth. you may need to do this several times. Concentrate the part of the glass were this image problem is just by the orientation of the document you are installing with the direction of the document you are passing through the ADF.
It will take several attempts, but with each try, make a new test from the original document, unyil the problem disappears.
I believe this will solve your problem, Best , Steve
Mar 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Not printing correctly from computers
try makling a copy from the glass if that is good then your problem lies with your net work try reboothing the colorpass, also have someone else print if you still have blank prints your color pass hard drive needs to be detach blow out then reattach
Jul 10, 2008 | Canon CLC 1140 Copier
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
jasbo
jasbo
