Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Water doesn't come out my Bissel rug cleaner model 7901
When I turn on the cleaner the brushes rotate but when I pull the water trigger nothing happens. Water doen't come out the bottom of it, and when you hook the hose up water doesn't come out of it either. What can I do?
  • Anonymous Dec 20, 2008
    The water doesn't come out
    Scholar:
  • 55 Answers
The flat belt on you machine has an access panel to it from the side of the machine. That belt runs the pump if it is broken or came off the machine won't pump.
Check to make sure both of the red/black circular rubber gaskets on either solution or recovery tank are on the tanks and not stuck down inside the inlet valves on the machine itself.
Make sure there is fluid in both tanks. Without fluid in both tanks the pump loses prime and will not work.
If all that checks out then you are down replacing the pump, but usually when the pump goes out, you will have a short burst of water when you first turn it on and then it stops working.
Hope that helps you out-Good Luck
Posted on Nov 25, 2008
Try this it happen to me take a part the upper half of the machine and look for the heater.take off one of the hoses and plow in it to see if ti is clogged it is take a part and clean out .
what happens is it gets clogged with soap and water when it drys out
Posted on Jan 23, 2009
Bissel vacuum cleaner
Some thing like rug or too much hair vine the brush to prevent the brush to spin when the motor is on. So it just keep pulling the belt that's why there is smoke.
-Check it , clean it and possibly need to replace new belt.
Good luck/Keep clean
Mai Lor
Oct 11, 2017 | Bissell Vacuums
Can't remove the lid on tank of Bissel carpet cleaner # 7901-R
Hey Anne! Once you remove the water tank from the machine, grasp the gray handle, turn it from the curved end to the flat end of the tank, and lift upwards.
Feb 19, 2013 | Vacuums
Bissell 7901-1 Cable that turns brush ripped. Where can I get a new one and how do I replace. Also when I turn to the high trafficsetting fluid doesn't spray out but it does on water only. Spinny...
If I'm understanding your question concerning cable/belt ,you can go to a bissel parts supplyer on line and order what you need ther are two bels that are envolved inthat area. The one that turs the brush is the belt with the teeth/cogs on it. To replace it there is an accesess door on the right hand side,using a screwdriver gently pry up on the door,which will expose the belt area .The belt that you are replaceing will attach on the brush then strech it to the point of the motor shaft, since one belt remains it's a simple prosses of elimination.the rest of your question is some what envolved I've requested info about the same area. So you might want to keep a look out for the answer tohow realign smartmix valve
Hope this helps.
Jun 17, 2011 | Bissell 7901-1 ProHeat Scotchgard Upright...
Will not **** the dirty water back in.
check for clogs in hoses and head.mine gets clogged up all the time.
Jun 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
PROHEAT BISSEL MODEL 7901-1
inside the upper part of unit there is a metal heating element which the water passes through, its probaly clogged,,,it gets filled with calcium build up from water..in future use distilled water or boil water before putting into these units
Dec 10, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel pro heat model 8910
Go to http://bissell.com/images/UserGuides/7901.pdf
This is in pdf format so you need adobe reader to get it, which is free on the net.
Aug 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
541 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
