Question about Whirlpool Duet GHW9150P Front Load Washer
F-H code During the was on the Normal /Casual cycle the machine stops and starts beeping with this code F/H flashing on and off. Why and what can I do to fix this? Thanks
  • Anonymous Nov 12, 2008
    my washer stops and flashes a F02 code.
  • 5,911 Answers
The following link explains the "FH" error code in detail:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
There's also some helpful advice another user provided at the end of the link (bottom of the page) that may also help you. Let me know if you require additional assistance. I hope this helps you.
Posted on Nov 11, 2008
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Replaced CCU, Sears washer still will not run
Suggestion: Unplug washer from mains. Open up the machine, disconnect and refit all connectors with wires one by one. Could be some loose connection somewhere. Also helps in the long run
Click if helped.
Mar 29, 2013 | Washing Machines
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
The cycle stops, beeps and flashes and H and F
f/h is a "no water entering " fault code. check incoming watersupply first, then check hte inlet watervalve screens for blockage
Feb 08, 2009 | Kenmore Elite 45986 Front Load Washer
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
115 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
