Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door shakes as if off balance when closing
Our garage door shakes when closing as if it is off balance. Sometimes so much that it causes the door to either stop closing or go back up. We haven't found any obvious loose parts. The opener is a 1/2 hp craftsman. We tightened the chain. Do the door springs need replacing? They are ~10 years old.
    Sergeant:
  • 227 Answers
  • The garage door may be out of balance or a spring may be broken. Close the door and use the emergency release handle to disconnect the trolley. Open and close the door manually. A properly balanced door should stay at any point of travel while being supported entirely by it's spring(s). If it does not, disconnect the garage door opener and call a garage door professional. Do not increase force to operate the garage door opener.
Posted on Feb 21, 2009
Our door didn't go down completely last night. Unplugged and replugged. It closed after that. However it also closed randomly when we went to back our cars out. Any idea if this is something going bad...
Could be the logic board is going out. Also check all of the garage door opener remotes and make sure that is not the cause. Some people will keep and extra remote in a drawer and something will touch it and activate the garage door opener. Or sometimes people keep the remote in the drink holder in a vehicle and that will activate the garage door opener.
Feb 15, 2015 | Building Materials
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Whisper Drive garage door opens and closes by its self
try changing frequencys you might have a neighbor close by that is using same frequency as you causing your door to open when they open theirs
Jul 18, 2012 | Home Security
Press the button for the garage door to go down and it will only travel a couple of inches and shakes. Unlatch the door and press the button and the door will catch the latch on the way down and close. ...
Most likely cause is the load limiters. Firstly, the door needs to work perfectly, when worked manually. No stops or restrictions through entire movement. Then reset the load limiters to spec and test again. Up limit is not extremely critical, but the close load limit can save lives and prevent vehicle damage.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 HP Whisper Drive. The lights are not working. I have replaced the light bulbs, and I can hear the relay clicking, but the lights do not come on. Other than this, the system operates...
Are you using the newer energy-efficient light bulbs? Most of the problems I have encountered are related to the newer bulbs. Sometimes they just do not make a good connection for some reason. If you are using the older-style bulb, try cleaning the contact points (with the opener unplugged of course), they can sometimes accumulate gunk.
Otherwise, it could be a loose wire- or bad receiver board. Just to make sure, though, definitely try a number of new bulbs to be certain that the bulbs are good.
Also, make sure you check the balance of your garage door, to make sure the springs are properly counter-balancing the weight of the garage door. Otherwise, the opener will work overtime and not last as long. You can see a how-to video on our website.
Feb 27, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door comes down and goes back up.
You need a general inspection of all related parts. Make sure none of the track mounting bolts have loosened leaving a misalignment of track segments. CAREFULLY with power off use fingers. turn EACH roller. Something as simple as a bad roller bearing can cause this, even a flat spot on a worn roller. Rollers can be bought at a home supply store. These are 2 most causes.
Aug 15, 2009 | Genie Company Genie 34538S Chain Glide...
Garage door will not open. no lights flashing on
Check to make sure that the lasers at the bottom of the door on each side are lined up. Sometimes it is easy to bump them and then they will not see each other causing the garage door to not work. Worth a try.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,691 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
