Question about Car Audio & Video
My Honda 2007 CRV - cd changer does not want to eject the cd's
Hi I loaded my cd changer with a 2 CD's, and wanted to eject one, but it stuck.. and just says error...push eject.. but it does not eject the cd..
  • Anonymous Dec 22, 2008
    also happening with my 2005
  • Anonymous Dec 28, 2008
    let me know if you find any solution.
5 Suggested Answers
Eagleeyes
  • 199 Answers
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
Posted on Jul 21, 2008
Eagleeyes
  • 199 Answers
SOURCE: car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Posted on Nov 25, 2008
smarthome2
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
smarthome2
  • 1114 Answers
SOURCE: 2007 Toyota Camry Hybrid CD changer jammed, one
Take it to any local car audio shop, find out the make of the changer and chances are good that it can be fixed quickly and at a minimal cost or replaced with an aftermarket unit that will work perfectly with the factory radio for under 600 installed easily. Hope this helps
Posted on Oct 03, 2009
Testimonial: "I think I will attempt a fix myself first. "
dancandoit
  • 436 Answers
SOURCE: The cd blaupunkt cd changer in my punto is not
It sound like the mechanism has jammed, this is common with this type of cd player as there is not a lot of room for movement in such a small place. the only thing you can try is pulling out the fuse in you car's fuse box for the radio and see if it resets the system. If this dont work then you will have to take it to a radio repairer.
Dan.
Posted on Dec 04, 2009
How do I eject cd stuck in my 6 disc cd player 2008 ford fusion
If it's jammed then the only way to eject it is to remove the cover of the unit to expose the changer mechanism. Locate the problem cd and remove it by hand. Close it all up and see if the problem is solved by loading another CD.
Feb 08, 2015 | Car Audio & Video
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
'03 Honda Accord 6 disk changer won't load/eject
i had the very same problem with a six stacker in my ford, the stacker inside has come of its tracks even by one or two teeth so when the cd tries to eject it jams on the side walls because of this alignment, only way to fix is to take it out and realign. may need to get a mechanic or your dealer to do it like i did as the computer system was attached to my cd player. not sure about the accord but this is a familiar problem with all sorts of 6 and 10 stacker cd players
Jun 23, 2010 | Car Audio & Video
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
1999 Honda CRV cd problem
try store bought disc first , replace the laser sounds bad although usually u will get an error code ,
Dec 11, 2009 | Car Audio & Video
Sep 29, 2009 | Car Audio & Video
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Jul 27, 2009 | Car Audio & Video
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Infiniti's FX-35 Bose 5 Disk CD Changer is totally Jammed.
I HAVE A 2003 INFINITY FX 35, CD CHANGER STOP WORKING,WHEN I TURN THE CAR ON SOUNDS LIKE IT WANTS TO EJECT, IT WONT LOAD NEDER.CD STUCK,CD CHANGER WONT WORK, PLEASE WHAT SHOULD I DO,,HELPPPPPPP. HOW CAN I GET THE CD TO EJECT. OR LOAD...
Mar 25, 2008 | Car Audio & Video
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
