I HAVE A KONICA 7145 COPIER WITH AN E56-1 ERROR
When I turn my copier on I immediately get an E56-1 Error. Looks to be a board issue? Any help would be appreciated.
  • 145 Answers
Main control board unit has been modified to prevent abnormal code.
[How to identify the style]
Current and new styles can be distinguished by the part number printed
on the main control board unit.
(Current) 40LA-9025 => (New) 40LA-9026
Serial Number Cut-in: 40LE02201
TRY
to reseat all the board connections first..
hope that help
Posted on Nov 15, 2008
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Where is the hard drive
check the following link, maybe it will help you:
http://diagramasde.com/diagramas/otros/7145-7222-7228-7235SM.pdf
Usually, the hard disks are located where all the boards are, due to the fact that hdd needs to be connected with this boards and if the wires are longer, interferences might appear.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub 7145 Copier
Konica 7145
fuser code hot part replace it
Apr 13, 2014 | Konica Minolta Konica 7145 Minolta Bizhub...
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Konica 7145 i have an error message 0006 I have replaced drum in drum assy. it gave me an f26-3 error message performed L detection now it gives 0006?
Check Toner control sensor board, on drum unit behind drum, is clean, try L-detect then, try it a couple of times. If that fails you will then have to change developer, and perform L-detect.
Sep 13, 2010 | Office Equipment & Supplies
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Oct 29, 2008 | Office Equipment & Supplies
495 people viewed this question
k24674
jasbo
jasbo
