When I swith to Ignition, security lights flash and will not stop, even though I have the key fob in my pocket. Security key indication stays solid.
SOURCE: Cannot start my 2004 Sportster 1200 Custom due to security system
Check the battery, try jump starting it with another battery. If the battery voltage drops too low, i believe the alarm default is to disble the bike. (Greasy little criminals will cut battery cables to disarm the alarm) so although you may have enough power to operate the lights and alarm, it may be droppoing too low to start.
SOURCE: installed new led taillight and now there is no brake light/blowi
i have a 2004 sporster custom with led tail lamp and turn lamps with engine running i have no running lamps or brake lights on rear but have all turn lamps working fine please help me with this problem also ihave checks all fuses and the brake lamp switch they are ok
hold key fob until signals flash,check speedo for solid key light,then try...if it still does the same thing,battery could be too low(will cause this also)
SOURCE: my 2007 road king security system will not let me
I long press sets the alarm and 2 short disarms it. It's possible the fob has fallen out of sync with the alarm. Hold the button down until the lights flash and that MAY reset it. Then disarm normally. You REALLY need an owner's manual to cover the alarm, The HD alarm is a good alarm, but notoriously hard to set up. It...now get this...takes 10 to 15 pages in the manual to cover operation and set up. Go buy a manual!!!
