Question about RCA P60921 60" Rear Projection Television
RCA P60921 60 in. Rear Projection not working
I posted something about 30 minutes ago about our "Philips" tv not working....I lied. It is an RCA. RCA P60921 60 in. Rear Projection I believe. Anyhow...a few weeks ago, we were just sitting down watching tv when all of a sudden the tv started making this VERY LOUD "buzzing/screeching" sound that scared the bleep out of me. We went up to the tv to see what was going on and could smell a faint burning smell coming from the bottom of the tv. Any ideas? Is the tv toast?
  • 1 more comment
  • k10road Nov 11, 2008
    particleaudi - I will check the exact model in about 10 minutes when I get home. As posted above, I believe it is a RCA P60921 60 in. Rear Projection, but again, I will confirm shortly. The TV is just over 3 years old. Thank you.
    wow....my nose is growing! I lied again! But now that it's in front of me, I won't lie anymore. It is an RCA HD56W58. Chassis # is ATC321. I just read another post that sounded similar to mine and I read about Splitter and Deflection boards?? How costly is this and is it worth repairing? Can a non-TV tech fix this if you have some computer building comfortability?
    yes, it still squeals when we turn it on...that is, if we can get it to turn on. It decides at times that it doesn't want to turn on. The power light will flash several times and then go off. If I hold in the power button, it will turn on and make a loud sound. So...I need to order the flyback and the horz output transistor from global electronics? Any idea what the part numbers are? I know what the part numbers are for the high voltage transformer and for the splitter/distributor, but that probably won't help, right? My BF is really good with computers and removing/replacing parts, so I think he would be ok if he knew exactly what to doo. But, nonetheless, we may still have an expert. Thanks for your help.
  • 185 Answers
Could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Posted on Nov 11, 2008
  • A Schneider Nov 11, 2008
    need a chassis number it will be on there somewhere ctc... itc...atc ###
    aaah sounds more and more like a flyback... when you turn it on does it squeel still? if so you would have eaten a horz output transistor. this would be caused by a flyback short and would require both parts availible from global electronics... although this is not a super tricky repair it does involve removing parts and replacing.. these board are fairly delicate and are easily damaged. be carefull not to lift off the trace. beware .... since you would be working around high voltage you do so at your risk.
    if you have 0 experience doing this it might be wise to have an expert do it for you..
    flybacks tend to cost around $100 canadian and the transistor about $20...
    good luck
I have a 55" Sony Rear Projection TV and when I turn on he TV I hear the voices but it takes the picture about 30 minutes to come on? The bulb was replaced less than years ago
First is the model listed here does not use a bulb, it has 3 picture tubes. What is actual model number as I think wrong one is listed here.
Dec 20, 2012 | Sony KP-51HW40 51" Rear Projection...
Several years ago we purchased a Philips 60" Rear
It seems problem with convergence output section of tv and convergence output ICs need to be replaced by professional because it requires soldering work with proper tools.
Please call local tv repair shop to get tv repaired.
Thanks.
Jan 18, 2011 | Philips 60PP9202 60" Rear Projection...
RCA D61W130YX1 chasis AYCZZ1 Serial# C425C101C
hi there do you have sound ?? if so open the back and check for a bulb youself as i dont trust shops much anymore becaues they always want you to replace old models.
richard
Oct 15, 2008 | RCA D61W20 61" Rear Projection Television
RCA 50in Rear projection TV Turns on and off every 30 seconds-New
if u have only had it a month it should be under warranty get them to repair it
Sep 21, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Philips 46pp9302 about 5-6 yrs old after 20-30 min. shuts off
Just posted this elsewhere:
Is the cooling fan running?
If not, the set may be designed to shut down after a few seconds to protect itself (and you).
Aug 10, 2008 | Philips 46PP9302 46" Rear Projection...
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
I have a rca hd52w140
Does the unit show a flashing led on front panel. make any sounds. reset this tv if it works invloves unpluging the set for 30 minites.
Oct 16, 2007 | RCA HD52W140 52" Rear Projection...
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA P60921 60" Rear Projection Television Logo
371 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
