Question about RCA DRC8320 DVD Recorder/VCR
RCA DRC8320N connection
TV set (RCA ColorTrak model # FLR620TR) doesn't have input/output jacks - how do I connect my RCA DRC8320N DVD/VHS unit?
  • Dawn Perry Jan 02, 2009
    Found this on another site. Posting 4 others who may encounter same setback.
    By "Henry (Charleston,IL)"  from Undisclosed on 05/28/2006
    I have only one complaint with the RCA DRC8320N VCR/DVD recorder/player combo unit and that compaint is that the RF OUT jack on the unit won't output video to an older television that only has the screw-on "F" connector RF IN jack. This older TV doesn't have RCA input jacks on it. I called the RCA 1-866-775-0976 help number listed on the box and the person that answered my call said that I would have to buy a seperate RF modulator unit to get the older TV to work with this new model DRC8320N unit. All of the older VCR's that I have seen already have this RF modulator built in to them. All you had to do was connect a screw-on RF cable to the TV's RF In jack and then connect the other end of the screw-on cable to the RF OUT jack on the VCR and then you could watch the video output from the VCR on the attached television. All you had to do was set the TV to channel 3 or channel 4 and you were ready to watch your videos. Now it appears that this feature is not being included in the RCA model DRC8320N VCR/DVD recorder/player. I ended up having to connect the RCA VCR/DVD recorder/player up to an older VCR using the RCA cables to connect the DRC8320N to the older VCR. I then connected the older VCR to the RF IN jack on the TV and I was able to watch the output from the model DRC8320N unit. Everything on the RCA model DRC8320N worked as I expected once the TV was hooked up in this fashion, but I was disapointed to see that the RF modulator function is no longer being built-in to the equipment. Another thing to watch out for is the initial start-up of the DRC8320N unit. The screen will show a message on the front display that says "HELLO" and then "PLS WAIT" and then "INITIAL". The directions for what you are supposed to do when this happens are located on a small additional piece of paper that is not in the large instruction book. It took me a while to find this additional piece of paper so I wasted quite some time trying to get the unit to work and then I found the additional instructions. Until you folllow the additional instructions listed in this additional sheet, none of the front panel buttons on the unit will work. [...]
  • 190 Answers
SOURCE: need a manual for dvd-vhs
Dear Customer,
You can get downloadable manuals for your instrument on the follwing link http://tv.manualsonline.com/search.html?q=+drc8320n&submit.x=15&submit.y=0
Please rate this solution.. Thank You.. Good luck!!!
Posted on Jul 11, 2008
SOURCE: DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Posted on Sep 14, 2008
SOURCE: drc8320n rca dvd recorder
This unit appears to have a faulty power supply module. Poor design. I have the same problem with different caps needed to be changed then those suggested by guest Oct 08.
Posted on Nov 10, 2008
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
likha
  • 790 Answers
SOURCE: Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
Posted on Feb 01, 2009
Best way to transfer vhs to dvd
hi if u r using rca cables connect 3 leads to output of vcr then connect them to input of dvd recorder......connect another cable to output of dvd recorder & connect it to tv input terminals set tv to av .on remote also set input on remote for dvd recorder good luck
Aug 29, 2015 | Televison & Video
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I need assistance in connecting my DVC845E (VHS & DVD recorder) to my Samsung TV. A VHS will play but cannot get it to record.
Some of the Newer VHS/DVD units don't have cable inputs. If this is like yours you can hook a RCA Audio/Vidio cable from your Samsung TV Vidio/Audio outputs (if set has them) to VCR/DVD inputs................... Larry
Oct 08, 2010 | Sylvania DVC845E
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Hi
Thanks!
Feb 01, 2009 | RCA DRC8300N DVD Recorder/VCR
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
RCA DRC8320 DVD Recorder/VCR Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
