Question about Viking 31 in. DGCU105 Gas Cooktop
How do I adjust the flame on a Viking DGCU-165-5BSB Gas cooktop
Hi, I have a Viking DGCU-165-5BSB cook top using LP gas. The flame has large yellow tips. How do I adjust it to get a nice blue flame?
Thanks,
- Russ
  • 1314 Answers
SOURCE: Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Posted on Dec 30, 2007
Kgt1962
  • 59 Answers
SOURCE: Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Posted on Mar 05, 2009
Kgt1962
  • 59 Answers
SOURCE: Viking Designer Series gas cooktop not cleaning well
I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
Don't use anything abrasive as the aluminum will scratch.
  • 42 Answers
SOURCE: our viking gas cook top
it sounds as if the tap is partially blocked
Posted on Sep 30, 2009
  • 9 Answers
SOURCE: i have a gas viking cooktop (four burners), front
Remove the knob and using a tester turn the screw inside to increase or decrease the flame.
Posted on Oct 16, 2009
Flame height on my 36 " 6 burner Viking Range Top
remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
May 21, 2008 | Viking 37 in. VGSU161 Gas Cooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Viking 31 in. DGCU105 Gas Cooktop Logo
128 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
