Question about Kicker IX1302 Car Audio Amplifier
Shorted out amp!
I have a Kicker IX1302 amp. I had taken my speakers out and didn't put wire nits on the endz! So while I was riding I heard a small poping noise, and saw a little bit of smoke! Now it will power up but there is no sound! Can u help me THANX!!!!!!!
    Scholar:
  • 119 Answers
Sound like you could have shorted out your audio o/p transistors. if you take the amp apart you should find 1 row on each side of the amp, one side is power & the other is usually for your sound out. the transistors on the audio side out could be bad, look closly to see if they are bubbled,cracked or just dont looke in as good shap like the others. these audio transistors work in pairs, so replace them in pars even if only 1 is bad. if they all look ok, test them with a multi meter to see if they are shorted. good luck.
Posted on Nov 09, 2006
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Check ohm reading of the speaker. Should read close to whatever the spec is (2 ohm, 4 ohm, 8 ohm) if you have multiple subs and no ohm meter then try connecting one at a time to the amp. Either you have a shorted sub, ohms are too low for the amp or you have an (least likely) amp problem tha y only shows up under a load.
Aug 01, 2016 | Kicker Car Audio & Video
Speakers pop or rumble when stereo is turned on
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Apr 24, 2010 | Kicker ZR600 Car Audio Amplifier
My friend was hooking up my amp in my car , had the green light lit up , then he was tightening the hot wire to the amp , and nicked the side off the amp with the screw driver , and then there was tiny...
IT MAY be just fuses inside the case. You could check... Also check the Reverse Polarity Protection Diode too. But often an event such as this will trash the units power supply and more.
Feb 04, 2010 | Kicker IX1302 Car Audio Amplifier
I have a kicker 750.1 amplifier. I was playing it one day pretty loud and it cut out once the bass hit and started smoking.The gain was up about 1/4 and the bass boost was about half way. what could of...
I would say that your subwoofer Or speaker leads have shorted out...when the bass hits as you say it drives the amp hard but if it is trying to dump power onto a shorted speaker or speaker wires it will blow the output power transistors not to mention other vital components of the power amp...i suggest you test your speaker leads with a Multimeter on the ohm setting before connecting a repaires or another amp.. to make sure there is no short on the leads and that the resistance is around 4 ohms or so depending on how you have your drivers wired...but anything lower than 2 ohms will cook an amp! you can normally pick up a meter from anywhere for around $10..
Jan 14, 2010 | Kicker (ZX750.1) Car Audio Amplifier
When my zr1000 amp kicks on it automaticaly averheats and shuts off it is also hot to the touch what should i do
One great amp !!! I would send it in to kicker. It looks like you may have one or more mosfets that are either shorted or on the way out. Does the amp have any protection lights that may give an indication of the source? Some thing that come to mind are: Shorted outputs, Speaker wires shorted or touching ground, power supply mosfet's
Nov 13, 2009 | Kicker ZR1000 Car Audio Amplifier
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Where can i get a pcb drawing for a kicker ix1302 amp please
Really the only place that would have one is Kicker and then again maybe a car stereo shop but I can assure you that if (and I say if) they do have it they will not give a copy for free if they give it at all
Nov 03, 2009 | Kicker IX1302 Car Audio Amplifier
Kicker protection light won't shut off
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Jun 29, 2009 | Kicker KX300.4 Car Audio Amplifier
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Kicker KX800.4 Protection light problem
If the voltage is sufficient on the B+ and remote terminals and the amp goes into protect with no speaker wires or RCAs connected to the amp, it probably has shorted output transistors.
Let me know if you have any other questions.
Oct 15, 2008 | Kicker KX1200.1 Car Audio Amplifier
Kicker IX1302 Car Audio Amplifier Logo
130 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
