I have a TB110MW9 DTV digital to analog converter box. I set the RF out setting and now the box is unresponsive. How do I get my digital signal back?
  • 4 more comments
  • Anonymous Jan 05, 2009
    I have a TB110MW9 DTV digital converter box. After setting up the stupid thing we scanned for channels as directed. After this was completed a little box saying No Signal appeared. Then for some stupid reason we messed with the RF out setting in the hope of getting a signal and now the box will not respond at all. Help!!
  • Anonymous Jan 12, 2009
    help. i have this exact problem.
  • Anonymous Feb 02, 2009
    There power light just blinks for like twenty seconds and then the unit just turns off. While it blinks there is no picture or sound I've tried holing down the setup button and nothing works. Any ideas?
  • Anonymous Feb 20, 2009
    everything worked just fine at first, but after like 2 minutes the box just shut down...
    now when i try to turn it on, it just blinks and turns off like the previous guest's
  • Anonymous Apr 01, 2009
    I PUSHED THE RF BUTTON TO OFF
  • smokie231 May 11, 2010
    what remotes are you using, the one that came with the converter or a universal remote?
Just a note. that you may want to go near the box while holding the setup button. also, it may take more than 3 seconds for it to respond. during tests. it could take up to 20 seconds for response. but this does solve the RF OUT for sure. hope this helps
Posted on Apr 03, 2009
Try to put it on the channel that it was on before usually 3 or 4. Then hold the setup button for the 3 seconds and make sure the unit is on. That should fix it.
Posted on Jan 15, 2009
I have a TB110MW9 DTV and Im trying to program the remote control to turn on and off my tv, any idea how to do it?
Posted on Jul 28, 2009
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HOW DO I SET MY UNIVERSAL RE MOTE FOR MY CONVERTER BOX
To be honest I never got a universal remote to work Magnavox TB110MW9 DTV Digital to Analog Converter
Nov 16, 2015 | Magnavox TB110MW9 DTV Digital to Analog...
My box shut off and when I turn it on the green light flashes 4 times then stays lite but no pic or sound what o I do
Make sure that your set is tuned to channels 3 or 4. If so and still nada, then your converter box has died a noble death.
Oct 15, 2015 | Magnavox TB110MW9 DTV Digital to Analog...
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
Magnavox dtv digital analog converter
It sounds that the Closed Caption function is On. Set it off.
Apr 29, 2013 | Magnavox TB110MW9 DTV Digital to Analog...
We were given the TB110MW9 Digital TV DTV Converter Box for Analog TV but with no remote . we do have other remotes we've kept from our last box that also died.would we be able to use this re
I thought that model number looked familiar. The answer is a qualified yes. If you have a Magnavox or a Philips remote it should work. If you have a universal remote try to search for a code that will control the box.
Nov 29, 2012 | Magnavox TB110MW9 DTV Digital to Analog...
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
1,018 people viewed this question
Top Televison & Video Experts
Electro Med Services...
