Question about RCA Open Box, Missing Non-Essentials DCR-8000 DVD RW RECORDER/PROGRESSIVE SCAN
Some commercial DVD movies will not play
My RCA DRC-8000 will on two of my DVD's only play the previews. When it comes time for the actual movie to begin it goes back to the play disc menu. This will happen over and over again. This only happens for two of my movies.
SOURCE: Language Selection for RCA DRC 220N
try to find an original remote in a pawn shop, sometimes they have extra remotes because broken dvd players, or other reasons they only know.
Posted on Dec 08, 2008
  • 814 Answers
SOURCE: RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
Posted on May 15, 2009
SOURCE: attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
Posted on Jul 03, 2009
  • 8457 Answers
SOURCE: I have a rca drc 8295 and have old family movies
Use the DVD+R Disc better for transfering recording.Read ur DVD Recoder/VCR combo owner manual,before u do this,for the correctly setting to do transfering recording.
Posted on Jun 23, 2010
  • 1557 Answers
SOURCE: Hello... My RCA DRC69702 portable dvd player is
have the lazer cleaned its dirty go purchase a lazer disc cleaner from any electrical supply store that sells tv,s and dvd players .
Posted on Mar 01, 2011
  • 6993 Answers
SOURCE: RCA DRC 8300N DVD recorder
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Posted on Mar 29, 2011
0 characters
1 Points
PLays movie previews will not play movie
You may need a firmware update, go online to Sony, contact customer support and the technical department for answers, they should be able give the information that is required to help get this problem resolved.
Apr 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
I have a rca drc 8295 and have old family movies on vhs and want to record to dvd. what dvd do i need dvd r?
Jun 23, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Our sd-k741 player is playing previews but not the actual movie itself. Once the previews are finished, we get to the main menu and then we hit "play movie" and we get an circle with a slash through it and...
If it does this with Any/Every movie no matter what, then your "Brain" in your unit, has gone faulty, and is freezing at the Load the Movie loading instructions, perhaps bad RAM, or a HDD problem whatever, you will have to get it serviced.
Jun 01, 2010 | Toshiba SD-K741 DVD Player
Have a phillips DVDR3455H/97 dvr. rented a dvd and it will play all previews. when i select to play the actual movie, it never plays it. display on dvr says ''menu''. suggestions?
Some DVD players use different button's to start the dvd movie from the main menu be sure to try them all mine has a play button but you have to press "enter" to get the dvd to play...the unit displaying "menu" is normal
hope this helps,ben
Aug 11, 2009 | DVD & Blu-Ray Players
Sony Blu-Ray plays preview but won't play the featured movie
try clicking on chapters to access the dvd
hope this helps
kind regards and don't forget to rate us please
Nov 28, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Model DRC 8310 RCA VCR/DVD player/recorder combo.
Did you put a splitter onto the cable signal? If yes, the signal is attenuated to much and there simply isn't enough signal for the recorder to decode. Call your cable company and request a signal amplifier be placed on your line. It's usually free.
Mar 15, 2008 | DVD & Blu-Ray Players
Recording a movie that I have on my pc to a disc useing a RCA DRC8335
if you have an s video out as well as audio out on your laptop connect it to svideo and corrasponding audio input on dvd recorder. hook up recorder to a TV to see the movie your transfering then press record on drc that should be good luck
Sep 01, 2007 | RCA DRC8335
DVD & Blu-Ray Players Logo
Top RCA DVD & Blu-Ray Players Experts
Are you a RCA DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
