Question about Audiovox FPE4216P 42 in. Plasma HDTV
Computer wont boot up
Asus k8s-mx motherboard 3100+processor just buillt a computer with this switched it on everything working fine decided as there was only 256 of memory to add an extra 1gig to speed it up this was pc3200 400 mhz ddr now it wont boot up when i switch it on the fan in the main power works the cpu fan works the usb mouse lights up the led case lights wont come on there is no power going to the dvd or the hard drive can you please help what have i done wrong
many thanks mike
  • 45 Answers
Reseat RAM, CMOS re-boot.
Posted on Dec 21, 2008
I am having asus K8S MX motherboard with amd2800+ processor. when connecting sata hdd it is dtecting in raid mode only .what is the solution to read the sata hdd in normal mode of booting.the raid is...
hi! are you having problem with sata booting system?pls try this solution,
first turn on your computer,and press del when the setup system appear try to look for advance settings or ferephiral setting and look for the sata setup,turn disable setup to enable or on.and press f10 to save setting,
hope this will turn your sata boot to normal mode,,,:)
Dec 07, 2010 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
I've AMD Athlon 64 bit processor 2800+ Motherboard Asus K8S-MX Series SiS 760 Fx series chipset BIOS version: 08.00.11 How can I save my current bios and update bios??
you must plug in your pc with ups
do step by step from internet and alwayas choice last date
http://support.asus.com/technicaldocuments/technicaldocuments_content.aspx?no=714
for download =http://drivers.softpedia.com/progDownload/Asus-K8S-MX-Bios-1013-Download-13287.html
1st thing you'll need to do is go to the motherboard manufacturer's website & download the new BIOS file & the flashing program. These 2 files will have to be copied to a bootable floppy, then you'll have to boot off it & do the update from DOS. The motherboard website should have a detailed explanation on how to perform a flash...print out the instructions & follow them exactly & you should have no problem
Nov 12, 2010 | ASUS K8S-MX Motherboard
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
Sound drivers
You can download the drivers from here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Select you OS at the top and you'll see all downloads below that.
Cheers!
May 02, 2009 | ASUS K8V-MX Motherboard
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
Overclocking failed ASUS K8S-MX
i assume it wont boot back up? If you reset the CMOS on the motherboard by moving the jumper on your board as per your manual. this will reset you settings to default setting, and let you reboot. If you don;t have you can downlaod the manual, drivers and much more for your model, from the web site at this address: http://support.asus.com/download/download_item.aspx?product=1&model=K8S-MX&SLanguage=en-us
please rate, thanks. good luck
Jan 22, 2009 | ASUS K8S-MX Motherboard
To download Asus k8s-mx motherboard driver
Hi aneeshkem,
All the driver's for the Asus K8S-MX motherboard are listed at this link.
http://support.asus.com/download/download.aspx?modelname=K8S-MX&SLanguage=en-us
Enjoy!
Mike
Jul 31, 2008 | ASUS K8V-MX Motherboard
Audiovox FPE4216P 42 in. Plasma HDTV Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
