I have a Toshibe Satellite 1400 notebook. It was working with a D Link wireless router and now the icon for wireless is not showing under connections. Why would it work and then not work?
  • 13,433 Answers
There is a wireless ON / OFF Switch on the right side of the laptop, this needs to be on the ON position for the wireless to work. Next to it is a wireless status LED light should come on this led when the wireless is enabled, if switching the switch to ON doesn't help turn the computer off and make sure the switch is on On position and power on the laptop. Wireless LED should light up atleast when you are at desktop if it doesn't light up. Turn the laptop off and start up again, now repeatedly move the switch from off to on during windows start up the led should come on, when the led comes on leave it on the ON position.
Posted on Nov 16, 2008
  • 1,879 Answers
Is it happening on one spot only or depends on location ?
Posted on Nov 11, 2008
The wireless connection in my Toshiba 1400-S151 won't maintain a connection. It disconnects every few minutes for a few seconds then reconnects. The signal strength to the router says very good to...
This could just be the setting in Device Manager under that adapter's Properties then Power Management. Untick the option "Allow the computer to turn this device off to save power", click Apply and OK your way out.
Jul 01, 2017 | Toshiba Satellite 1400-S151 Notebook
My Toshiba 1400-S151 seems keeps loosing the wireless connection to the router. The signal strength is excellent to very good but when connected, it will disconnect every few minutes for a few seconds then...
Try disabling Bluetooth. I found this allows the wireless to run smoothly. Disable wireless when you don't need it and Bluetooth will run smooth again. Bluetooth and wireless Can be on the same chip and causes interference.
Sep 25, 2017 | Toshiba Satellite 1400-S151 Notebook
Toshiba Satellite A105-S4014 15.4" Notebook with
If the drivers aren't loaded, it won't work properly.
Please check your model number as I cannot find it on Toshiba's database.
Try www.computers.toshiba-europe.com and let Toshiba detect your model.
Toshibe supports most models.
Nov 17, 2010 | Toshiba Satellite A105-S4014 Notebook PC
How do I get this prehistoric Toshiba Satellite 1400-S151 to work with wireless? Do I need a wireless card or something completely different? When it click on the wireless icon on the lower right hand...
1st.: check to see if there is a wireless button on the outside of the computer. Some have this option to turn it on/off and it's easily overlooked by many.
2nd.: Right click "my compuer" and go to manage. Go to "device manager" and find your card under the "network adapter" tab. If it is disabled, double click it to enable it. If it has a yellow flag on it, you will need to download and update the driver.
Mar 25, 2010 | Toshiba Satellite 1400-S151 Notebook
I connected the LCD Projector to L300 , satellite Pro Laptop but nothing happens. how do i configure ?
I have a Toshibe Satellite L30 and am having problems to connect the projector (BENQ 620c). It shows only searching and do not find the signal. I have tried with FN + F3 or F5 but it does't work. Can you help me to solve this issue? Thanx
Nov 19, 2009 | Toshiba Satellite Pro L300 Notebook
My new Toshiba Satellite L300-20W will not connect to the internet via my wireless broadband connection (which is working fine as I tried another computer with it). The Connectivity Doctor gives the...
This problem is common.
This error message occures when the wireless card does not get an IP address from the wireless router. To get the wireless router to issue the wireless with a new IP address the connection needs to be repaired.
Right click on the wireless icon and click on repair.
Jul 30, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Can´t get an IP valid address on a Toshiba a65 with a Realtek LAN NIC Card that shows well installed, working, perfect a properly reconignized within the system, although there´s no error showing...
Power off your wireless router for 30 secs. and power it up again wait till all the LED are on and functioninh normally.
THEN
Reboot your laptop OR
Right click on the wireless icon and click on Repair - this will force the wireless card to obtain a new IP address from the wireless router.
May 02, 2009 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
WLAN is not working
Hi masif - please don't rate this yet! Unplug your modem and router. After 60 seconds plug in your modem. After the modem lights return to normal, plug in your router. Give it 15 seconds and then try it. Let me know what happens.
Jeff
May 22, 2008 | Toshiba Satellite Pro 6100 Notebook
Network Cable Unplugged
This is odd as the connection icon with the cross on it refers to a wired connection and not wireless. Right click the icon then select dissable. Go to your wireless card in network connections and right click then connect. Also go into your routers properties and see if it is allocating your wireless card an IP address, this should show along side your other PC's allocated IP addreses.
Dec 13, 2006 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
