Question about IBM NetVista PC Desktop
My video (onboard) will not start the computer starts and runs
Hi its an onboard video and it just wont light up the monitor
    Sergeant:
    Champion:
  • 275 Answers
Remove the cmos battery and than start the system and are u getting any kind of beep sounds?
Posted on Nov 11, 2008
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Jan 26, 2013 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
Black Monitor, (NO SIGNAL FOUND)
Start your computer with monitor attached to the onboard graphics poart,
go to bios,
search for graphics setting and change it to PCIE.
Exit while saving changes connect your cable to graphics card port.
This will solve ur problem.
Nov 25, 2012 | MSI N210-MD1G/D3
My Acer aspire ax1700 PC dsektop wont work and here are the steps I took: First one day it wouldn't power up - The power led would blink once the fan (power supply) would come on for a split second and...
Hi, I had the same inital problem as you, except I didn't put a new video card as I was please with the Onboard card performance that even has an HDMI port. Not sure if your problem is solved already, but in my working process, I first suspected the Power Supply, and I had everything out of the case but the Mother Board. When I tried to fire it up I was always getting "No signal" on the screen, not even a blink from the BIOS. I then put everything back in place, then after the HD started spinning of and Windows booting, the screen started coming on. I felt it was like if I needed Windows to have a clean booth to replace the video drivers and switch to the InBoard card. Hoping this of any help.
Feb 12, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Dell gx280 wont run I installed new video card in pci e slot
I had exactly the same problem on my friends Dell GX280. It will only let you use the onboard card or the new radeon card not both together. In the end we had to buy a Radeon card that was made specifically for two monitors and disable the onboard card on BIOS. It would not let us use the two seperate cards in unison.
May 06, 2010 | Dell OptiPlex GX280 PC Desktop
Monitor wont work
You were not very clear with your question. If you mean you have disabled your onboard video, then installed the new video card and get nothing then the card is not compatible with your system OR you got a bad card. If you mean you simply installed the card, turn on your computer and get nothing until you move your monitor plug back to the original port (without turning off the computer) then you must disable your onboard video by going into your BIOS settings. Follow the instructions that came with your video card or your computer to do that. Usually you get in by pressing delete or F2 while the computer boots.
Jun 06, 2009 | Evga e-GeForce 7300GT 512MB Graphic Card
Computer start but wont Boot up.
Here are a couple steps you can do to verify something didn't come on correctly.
- Verify the monitor cable is connected tightly to the monitor and PC.
- Verify the power cable is plugged in.
If both of these check out is there a little LED light on your monitor that is on?
If not swap it out with another monitor and see if a different one works. If so we have a bad monitor.
If both do not work you may have a video card issue. Most EMachines come with a onboard video card which is bad news. If you have a onboard video card you will have to verify the warrantly though Emachine and get it fixed. Good luck and I hope things go well.
May 02, 2009 | eMachines W3623 PC Desktop
Monitor stuck in power save mode
This might be problem with your with your monitor or videocard.
Click Here to Troubleshoot.
Thanks, PREM
Mar 31, 2009 | Dell Dimension E520 PC Desktop
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
Hi, i am workiing on an emachine T6420 for my brother and this thing starts up with the fans running and a black screen. my monitor that i connected to his computer shows a yellow standby light on the...
That's exactly what it sounds like. I would put in a new video card (or used one, if you have one) into one of the expansion slots and run it from there.
I would suggest to go into VGA mode just to make sure, but since your monitor never even gets off standby, I'd be 99% it's the onboard video.
Hope this helps!
Dec 28, 2008 | E-Machines T6420 PC Desktop
IBM NetVista PC Desktop Logo
89 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
