Question about Mitsubishi WS-55809 55" Rear Projection Television
Hi I'm looking for the circuit board control panel.
Can you let me know where I can find one for a Mitsubishi WS-55819 thanks you
  • 85 Answers
TV does not power on - Mitsubishi WS-55819
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Mitsubishi WS-55819 55" Rear Projection...
I have a Mitsubishi WS-55819 and the screen is curved and looks 3d. The colors are also blurry. When it warms up it looks better. Any suggestions?
It could just be the solder on the convergence ICs which needs to be reflowed. If that doesnt help then the ICs will need replacement. Your model uses 2 of the STK392-570 ICs. If you need further assistance please let me know.
Thanks
Sonny
Jun 09, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Model WS55819, shut off and won't turn back on. The first few times I tried to turn it on, the indicator light came on and went off after a few seconds. Now there is nothing. I removed the panel from the...
Most common problem in WS-55819 is failure of convergence output chips and blown pico fuses in power supply section.
You need to read out error code in tv, procedure is as follows:
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "24", the LED will flash two times, pause, and then flash four
times.
Error codes detail:
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
This way you can determine what section got problem in tv and causing problem.
Let me know if you need further info.
Thanks.
Dec 13, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Aug 10, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
May 27, 2009 | Mitsubishi WS-55819 55" Rear Projection...
WS-55819 55 vertical hold problem
HELLO. SOUND' LIKE U NEED TO GO BACK TO WHERE U STARTED.!!! AND LOOK OVER WHERE U SOLDER IN THE IC's. !!! ON THE MOTHER BOARD. & MAKE SURE THAT NONE OF THEM ARE NOT TOUCHING ONE ANOTHER.!!! OR POSABLY .!!!! U COULD OF GOT SOME SOLDER ON THE BOARD .!!!! WHERE THERE SHOULD NO BE.!!! SO LOOK OVER THE BOARD REAL GOOD.!!! AND SEE IF YOU CAN FIND. !! ANY THING.!!! LIKE .!!! WHAT.!!! "AM".!!! TALKING.!!! ABOUT. SOLDER THAT DRIPED OFF .!!! ON TO THE BOARD. WHEN YOU WHERE SOLDERING. THE IC's BACK IN TO PLACE.!!! LET ME KNOW IF THIS HELP'S YOIU. OK. "GOOD LUCK"
Jun 27, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS 55859 Green light flashing
HELLO. WELL SOUND'S LIKE YOU A PROBLEM.!! THAT COULD BE A FEW DIFFRENT THING'S.!!! FIRST THING YOU WANT TO DO IS UNPLUG THE SET..!!! THEN TAKEOFF THE BACK.!!! AND LOOK FOR FUSE'S ON THE BOARD. TO SEE IF YOU HAVE A BLOWN FUSE.!!! GET BACK TO ME AND LET ME KNOW .? OK ASAP. "GOOD LUCK"
Jun 15, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi big screen
Are you looking for the circuit board control panel? Or the actual frame that houses the buttons/ I have access to tons of mitsubishi parts.. Let me know what it is that youre looking for, I should be able to help you.
Apr 07, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
146 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
