Question about HP Office Equipment & Supplies
My HP photosmart C4200 ALL-in-One series is telling me is telling me that my print cartridge is missing or not detected, I just barely replaced the ink.
    Guru:
  • 859 Answers
Below is a partial entry of the help document at HP. The complete text can be found by clicking on this link here.
If you have already read and completed these steps, please notify me that you have by using the Text Area Comment Box below. Proivde me with any thing else you have already tried. Lastly, do you have a manual for your printer in digital format that you can place on your PC and refer to? I can post one here for you if you need it.
Essentially, there is no easy Trick to clearing this issue. The most common error made by users it in replacing both cartridges at the same time. Each cartridge should be replaced individually. Once completed the printer will want to execute a print head alignment test. This print out will include instructions on selecting the numbered lines that line up most exactly. Then you would enter the corresponding number.
Bypassing or interrupting this alignment test after replacing cartridges will cause error messages such as yours. So, if you did this out of ignorance or confusion, remove each cartridge one at a time using the method descrbed below. When both have been removed and reinstalled and the alignment process completed you should be error free. Should you still receive this error, remove and clean each cartridge using the method described below, one cartridge at a time.
If after completing all the steps below, you still receive the error message, your printer has a larger problem that is internal hardware related. You can either replace the printer or have it serviced by HP. Most people opt to replace the printer as an error such as this at the internal hardware level usually indicates that the printer has reached the end of its usable life span. If this is happening prematurely, have it serviced under warranty. Printer warranties are usually one year from HP. If you purchased using a credit card you may have an extended warranty. Check with your card company right away for information on any extended warranty you have from using your Credit Card.
If you have any further questions, please ask me using the comment box below.
Regards,
Worldvet
Solution one: Remove and reinsert the ink cartridges
  1. Turn the product on.
  2. Make sure to have letter or A4 unused, plain, white paper loaded in the input tray.
  3. Open the ink cartridge door.
    NOTE: Make sure that the carriage holding the ink cartridge moves to the right. If it does not move to the right, turn the product off. If it is a new product, make sure all the packaging material is removed. Close the ink cartridge door and then turn the product on again. The carriage should move to the right. Figure 1: Opening the ink cartridge door My HP photosmart C4200 ALL-in-One - c01333689.jpg CAUTION: The product must be turned on before the ink cartridge door is opened. If the product is off when the ink cartridge door is opened for access to the ink cartridges, the product will not release the cartridges. The product can be damaged if the ink cartridges are not docked safely before removal.
  4. Wait until the carriage is idle and silent, and then lightly press down on an ink cartridge to release it. The error message should indicate the problem cartridge by displaying an icon that represents it.
    • The tri-color ink cartridge is in the slot on the left.
    • The black or photo ink cartridge is in the slot on the right.
    Figure 2: Pressing down on an ink cartridge to release it c01333690.jpg 1 - Ink cartridge slot for the tri-color print cartridge 2 - Ink cartridge slot for the black and photo ink cartridges
  5. Pull the ink cartridge toward you out of its slot.
  6. Make sure the tape has been removed from the cartridge. If the tape has not been removed, remove it now. Figure 3: Removing the tapeMy HP photosmart C4200 ALL-in-One - c00880894.jpgsrc="http://i.fixya.net/uploads/images/c00880894.jpg" alt="c00880894.jpg" class="h_mi" /> CAUTION: Do not touch the copper-colored contacts or reattach the tape.
  7. Hold the cartridge with the HP logo on top.
  8. Reinsert the ink cartridge into its slot by gently pushing the upper part of the ink cartridge forward until it clicks into the socket. CAUTION: When installing the ink cartridge, do not rest your hand on top of the product for leverage. This might cause the carriage to lift out of position. Figure 4: Incorrectly grasping My HP photosmart C4200 ALL-in-One - c01333691.jpghe product for leverage c01333691.jpgFigure 5: Pushing the cartridge in firmly c00853118.jpg
    • When installing the tri-color ink cartridge, slide it into the left slot.
    • When installing a black, photo, or gray photo ink cartridge, slide it into the right slot.
    My HP photosmart C4200 ALL-in-One - c00880896.jpg Tri-color cartridge in the left cartridge slot and black cartridge in the right cartridge slot c00880896.jpg
  9. Close the ink cartridge door.
If the error message persists, continue to the next solution.
Posted on Nov 11, 2008
  • Glenn Rogers
    Glenn Rogers Nov 14, 2008
    Do you want to continue working this problem or have you solved it already? I'm willing to work with you beyond this first step if you are wiling to work with me. There are many other options in troubleshooting printers. So, it can be solved, it just entails a bit of work. For me and the rest of us here at FixYa, diagnosing and working with a customer via email alerts to posts on a board is very difficult. But, we do this all the time. It just requires a note from youm you are willing to work this through to the end.
    WV
My hp photosmart C420 will take the commands but will only print blank pages
maybe u check the laser or a transfer belt or some contact bias from a cartridge
Feb 19, 2013 | PrintCountry HP Photosmart C4200 Series...
My Hp photo printer C420 takes the command but prints out blank pages
check transfer belt a cartridge some contact bias plate laser unit some posssibilities isolation
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Wont detect
1. Make sure that you removed the tape covering the metal contacts on the print cartridges.
2. Clean those contacts with a cotton swab and distilled, filtered or bottled water. Tap water may damage. Do not touch with curious fingers. Allow to dry.
3. Reinsert, Reset printer.
Feb 04, 2009 | HP Photosmart C4280 Aio Printer
Trouble with scanning and printing
One of my friend faced a similar problem and he referred this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00880901&lc=en&cc=us&dlc=en&product=3192753&lang=en
Please let us know if the solution solved the problem and kindly rate.
Jan 06, 2009 | HP Office Equipment & Supplies
I have a HP Photosmart C4200 series printer. I want to use an alternative supplier colour cartridge, but it won't print! I feel it should. How do I make the printer print with this cartridge?
Contact the dealer for the alternate cartridge, you probably have a defective cartridge that should be replaced under warranty. The third party cartridges are generally remanufactured, cartridges that have been used once (or more) before, then refilled. The quality varies widely. See here for a study of third party cartridge quality.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Aug 20, 2008 | HP Office Equipment & Supplies
2,735 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
