Question about Lexmark X73 All-In-One InkJet Printer
Need help My computer recognizes my printer and it goes through the motions of wanting to print.But when it starts to feed the paper it feeds on the right side more then the left side of the paper.Meaning the right side feeds first and doesn't feed evenly.If I could get some help I would greatly appreciate it.
  • ruby20 Apr 07, 2008
    When I go to print the paper doen't feed through. and then some times it does when i shut the printer off and then on the paper comes out.
    Genius:
  • 2,035 Answers
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
The photo paper does not feed into printer. I
Get hold of the photocard and try, with your fingers, to curve the end that goes into the printer first so that it doesnt resist as the machine tries to pick it. Just curve/bend it little upwards, not downwards. Usually this kind of problem is temporal and happens especially when the card is a bit too hard for the machine.
Dec 09, 2009 | Office Equipment & Supplies
Paper feed problem with Dell 922
Take a cotton swab and some alcohol and clean the rollers. They may be filled with paper fibers.
May 03, 2009 | Dell 922 All-In-One InkJet Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
HP 7130 WILL NOT PRINT BLACK
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | HP Officejet 7130 All-In-One InkJet...
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
Lexmark X73 All-In-One InkJet Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
