Question about Dell A920 InkJet Printer
Dell 920 Printer is giving annoying horizontal white lines
Have tried changing the cartridge and doing the cleaning cycle recommended in the manual to no avail. Also tried with a better quality of paper with no success!!
Any ideas?
  • daf101 Nov 16, 2008
    Many thanks for the suggestion - unfortunately no improvement in print quality after cleaning the strip. Thanks anyway. Any other suggestions gratefully received - cheers
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
We can try one more thing here...
Cleaning the encoder strip...
1. Turn the printer off.
2. Take the power cable out from printer.
3. Open the front cover .
4. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer.
Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
5. You can move the ink cartridges manually to a side so that you can clean the strip completely.
6. Close the cover, connect the power and turn on the printer and try again,
It should work....let me know if it does
Posted on Nov 11, 2008
My hp1010 printer gives horizontal white line or bars between character.
Try a different cartridge, blank horizontal would point towards a possible drum issue. Does the defect repeat down the page?
Sep 12, 2016 | HP LaserJet 1010 Printer
White Lines through pictures and text
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update. After the update, perform the Deep Clean Printhead maintenance again.
If it doesn't help, replace the cyan cartridge.
Jun 28, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
White lines across the page on pictures. Have cleaned and changed cartridges. Any auggestions?
Are these lines Horizontal ? if so, clean the roller with lint free cloth from rear end of printer ( backdoor )
From Printer Setup - go to TOOLS - You will find Clean Cartridge option - press ok
Jun 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Streaky printing from canon pixma MP600
There is usually a maintenance button or similar in the "printer properties" dialog box to run a cleaning cycle."Right click" on your printer, select "properties", and you should see something. Try that.
Also, are these Original cartridges or compatibles / refills? Non originals can often cause image quality problems
Mar 01, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Problems with dell all-in-one 920 printer
1. turn off the printer
2. remove power cable.
3. move ink cartridges to center manually
4. clean the metallic rod with kleenex or WD40 if required
5. Make sure that lids are properly snapped in for ink cartridges.
6. Connect power cable and try again to print
let me know if that works
Nov 11, 2008 | Dell A940 All-In-One InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell printer
You can try cleaning the feed rollers and manually clean the ink cartridge carrier contacts. The issue may also be the encoder which is a narrow band of transparent plastic behind the ink cartridge carriers. Try to clean this. Be careful as this can break easily.
Nov 27, 2007 | Dell 942 All-In-One InkJet Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Dell A920 InkJet Printer Logo
205 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
