Question about Cameras
Won't down load
The small wire that goes to camera to down load pictures, is lose, poor conection. Can it be fixed at store, or require factory I down load pictures to my PC, so there are two cords. A large & very small. that go into the holes in camera. The small conection is loose won't conect, so can't down load pictures. Can it be fixed at store, or need to be sent to factory?
  • 1solomon23va Nov 14, 2008
    Thanks, But I don't know about a memory card or USB memory card reader.
    Champion:
  • 225 Answers
Just use a memory card and a generic USB memory card reader. The cord system is a bad idea for any camera.
Posted on Nov 13, 2008
Kodak easyshare c1550
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 19, 2012 | Kodak Cameras
I have a fine pix z85/z90 camera the user guide is of a very poor quality. I cannot read how to up load pictures to my camera. I can't figure out how to use the usb cable.
Consider NOT connecting your camera to your computer.
Jun 24, 2012 | Cameras
Hi, I change the memory stick for a 4GB,and now every time I turn on my camera I need to set the clock(but it won't set!!).Then I put back the 2GB memory stick and I still have the same problem.
The memory card for a digital camera is only used to store pictures. The problem with your camera not storing the date correctly is most likely a battery issue. If you let the camera battery completely drain, it will reset to factory settings. If this is not the problem, I would suggest calling the company's tech support line, as they will be able to help you track down the problem.
Good Luck!
John Vickers
Sep 18, 2011 | Cameras
I dropped my canon camera and it says lens error restart again. i dont want to lose my picture but the lens dont go in. i can see my pictures but i cannot take a picture.
Any pictures you have taken in the past should be safely stored on the memory card. Make sure you copy them onto your computer to ensure you don't lose them while fiddling with your camera. You can use either an external card reader or you might be able to connect your camera to a computer using a USB cable.
A lens error is one that the average user can diagnose and fix. It usually requires a trained technician or worse (but sometimes cheaper), a replacement camera. You have already experienced that the camera will not take pictures with the lens error.
Good luck.
May 13, 2011 | Canon PowerShot A560 Digital Camera
When I try to download pictures onto my computer, the camera screen goes black. I have new batteries in it.
Try plugging the camera into AC power. Also, you could try to factory reset the camera, but that would cause you to lose the pictures. My best advise would be to get a cheap USB card reader.
Feb 15, 2011 | Kodak EasyShare C613 Digital Camera
Camera takes picture and stores it ,but won;t down load new pictures to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Sep 07, 2010 | Canon PowerShot SX110 IS Digital Camera
Dryer burns off wire at heating element-why?
Poor conection. A lose or poor fitting wire terminal will creat heat at the conection. Undersized wire will also make heat and burn wire.
Oct 31, 2009 | Amana DLE330RAW Electric Dryer
VPC-T700 Wont Turn on
hiak, I had the same problem with my camera. Try opening the battery cover and pressing down onthe battery while turning on the camera. If the camera turns on you have a poor conection between the battery and the camera.I folded a small piece of paper and put on top of the battery then closed the cover.Its worked like new since.
Oct 07, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Cyber shot dsc s600
The small nylon power button contact lever breaks easily on these camera. For those of you that are capable you can try to repair the lever but I have found this to be quite difficult and usually breaks after the fact. This requires opening up the unit and removing the dark grey L-shaped button piece and then repairing it. But, for those of you that just want to get the camera working again quickly with just a little inconvenience follow these instructions.
Drill a small hole in the top of the camera as indicated in the picture here. It will be right on top of the circuit board button cotact for the Power button. Just use a paper clip and stick it into the hole and depress it once to turn the camera ON. Same for turning in back OFF. Easy fix.
[IMG]http://i60.photobucket.com/albums/h18/PaPaBob_ppb/PowerButtonFix.jpg[/IMG]
Feb 18, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Problems storing pictures to Memory Card
Shawna, Since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem.
Aug 08, 2007 | Olympus EVOLT E-300 Digital Camera
Cameras Logo
155 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
