Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Bosch Exxel SGS43E08GB/45
Hi
I have had this dishwasher for a number of years now and it has been working without any problems apart from been noisy.
The dishwasher takes on water and dispenses it but no water is pumpued into the armsd and so they don't spin round to wash the dishes.
I read a post from somebody who had the exact same problem but the solution was a little vague for me.
I've also tried locating the manual from Bosch's website but my model isn't available for some reason.
Many Thanks
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
  • 42 Answers
SOURCE: my bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Posted on Dec 21, 2008
BIKER T
  • 909 Answers
SOURCE: bosch SGS43E08GB/45 DISHWASHER
Simply the bearings on the main wash motor need to be replaced. Hardest part is to remove motor from unit. Assuming you have available tools including a medium sized bearing puller you could D.I.Y. bearings can be bought at your local auto spares shop.
Posted on Jan 28, 2009
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
57 varieties
  • 1653 Answers
SOURCE: I am looking for the operation manual for my
You can download it from the following Bosch Support Link
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=ngfv1dacdcso0mchdb---alz&UMOBID=ngfv1ekcdcso0mchdb---alz
Posted on Oct 09, 2009
Would like a service manual for a bosch SGS43E08GB/43
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodlg.htm?Maktx=SGS43E08GB%2F43&eshoptype=S
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
First link is for spares, second is to download manuals.
No specific service manuals are available, if there is something specific you need to know how to do, please repost or add comment.
All the best.
Aug 21, 2010 | Dishwashers
Tip
Conversion chart for dH to Clark BOSCH EXXEL Dishwashers
I couldn't find any info on my new BOSCH EXXEL dishwasher the codes in the manual are all in dH (german) while the H:XX codes mean nothing unless you have this table I created here it is for you all so you don't have to worry, it has all the conversions between Clark, dH and mmol/l and mg/l if you find one that applies to you just look across the table and find your corresponding H code.
You will need to go to your suppliers own website to find one of the above numbers for the quality of water usually in mg/l they will give you this value and then you can select the H code for you area.
Water hardness is measured in either European °E (clarks) or in the German °dH( Deutsche Härte) you will find this on all Bosch Dishwashers if you water is Extremely hard then you will need to program your Bosch dishwasher using the Code H:06 to give you maximum protection, if your water like mine is Extremely soft then the H:00 works well and also saves you loads of dishwasher salt.
HARDNESS CHECK TOOL
• Clark degrees (°Clark)/English degrees (°E) conversion to mg/L calcium: divide by 0.175 One degree Clark corresponds to one grain of calcium carbonate in one Imperial gallon of water which is equivalent to 14.28 parts calcium carbonate in 1,000,000 parts water.
•Deutsche Härte (German hardness) (°dH) conversion to mg/L calcium:divide by 0.14 One degree German corresponds to one part calcium oxide in 100,000 parts of water
on Dec 12, 2009 | Dishwashers
My bosch exxel wont drain ,can you help? thanks
Hi there, I fixed it , it was a cardomom seed sticking the impeller.
Dec 25, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch exxel the display has two elongated boxes blank
Hi.
At a glance it looks like an electronic control board problem, what you are describing is not an error code.
Try first disconnecting power, either tripping circuit breaker, or unplugging the power cord. Keep the machine disconnected for a couple of minutes.
If that does not clear the error, try holding down the start button for six seconds, until the panel reset.
If still no luck , then the electronic control may need replacement. The part must be tested by a technician. A control assembly is expensive, and there are more parts that can cause the electronic timer to jam.
If you need to call a techncian or to buy parts you can ring the number listed on the owners manual.
Try first the reset procedure described at start.
Regards.
Nov 22, 2009 | Bosch Washing Machines
Should I buy a Bosch?
In my opinion, these do not live up to the Bosch name. They seem to come up on our radar here with "unusual" problems, and a lot of the questions posted go unanswered.
I replaced a beautiful stainless steel Kitchen Aid, after replacing the motor/impeller assembly because it was noisy, and the new one failed also. I bought a Samsung, and I like it. There a re several schools of thought about dishwashers, neither of them are very good, but here goes: One friend buys the brand name cheaper models. One buys only the higher end "best" types.
My best advice is to buy a brand with a high degree of reliability, and stay in the mid price range. The reason I say this is that the middle price range units generally have the better components of their "flagship" models, but don't have as many cycle choices, rack choices, etc.
GE, Whirlpool, (Samsung) are good brands. Frigidare is in there, too. I will never have another Kitchen Aid or a Maytag. I found them to be overpriced and unreliable, but this is just my opinion.
Best regards, --W/D--
Aug 11, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Exxcel Max USER MANUAL
hi maxine,
i have just sent it to you, please let me know when you get it.
thanks,
carmen
Oct 24, 2008 | Dishwashers
hi there,
if you send me your e-mail address, i will forward you the file in .pdf.
thanks,
c
Oct 23, 2008 | Dishwashers
Bosch SGS43E08GB/45 DISHWASHER
Mar 09, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
60 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
