Question about Pioneer AVIC-N2 Car DVD Player
Yellow screen My unit was working fine until one day I turned it on and the screen now has a yellow cast to it. Navigation still works, just everything looks yellow. What would cause this, and can I fix it?
I can only offer a guess as to what is causing this problem. The unit's LCD screen is powered by a flat ribbon cable, which can sometimes be seen from the top of the unit as the screen is sliding out. Try observing the cable as the screen is sliding out. If you can see any cracks in the cable, it needs to be replaced. Unfortunately, you will have to send it in to Pioneer to have that done. This issue is a known problem to Pioneer. If it is indeed the flex cable, they should replace it for free with a 5-7 day wait. The screen having a yellowish tint can be a sign that this cable is about to fail. I wouldnt worry about it now if you can still see your screen fine but if the screen goes out or gets worse, I would try to send it in to Pioneer to see if they will replace that cable for you. The URL of the page that explains this issue is http://www.pioneerelectronics.com/pna/v3/pg/top/cat/article/0,,2076_310069579_395713842,00.html Good luck with your unit.
Posted on Jan 13, 2007
Jvc kdr431 wont turn on
Check all of your fuses and make sure you are getting power to the red wire. It sounds like you are getting power to the yellow wire already. Both the red and yellow wires have to have power going to them in order for the radio to work.
Mar 13, 2013 | Car Audio & Video
DISPLAY HAS A YELLOW CAST
First test your monitor to another computer, if it works fine with another computer, then your video graphic card is damaged or the connection port, or cable is bad. and needs to be replaced. If the monitor do the same with the yellow cast with another computer, then your monitor may need to be adjust for coloring in the screen menu, or simply do a auto adjustment with the monitor option. If that donsn't solve the promblem then you need a new monitor.
Jan 30, 2011 | Dell Inspiron 580 Desktop Computer (Intel...
Projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
May 06, 2010 | Hitachi EDX-3280 LCD Projector
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
My XBox 360 does not show up on the tv screen, but it has sound.
this happens a lot. what happend is the red white and yellow wires that you put in the back of your tv. the red one is not in the right area or
there is a switch right were you plug in that cable with the red whit and yellow cables to your xbox that says hd or normal switch that to whatever your tv is
Jul 17, 2009 | Microsoft Xbox 360 Console
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
05 Dodge Dakota Navigation
Sounds like your describing the overhead console display?
If totally blank, check the 20 amp yellow fuse #14 as a 1st step.
Mar 06, 2009 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Im trying to get my nintendo 64 to work on my avic d3. i know i need a power inverter, what else do i need? also, do you know where the red white and yellow plugs from the nintendo 64 goes into the d3?
the red white yellow wires plug into the rear of the unit (white and red RCA will go into video or aux input) the yellow wire will go into video in (the red and white RCA from Nintendo they can go into either video 1input or aux input) on back of in-dash unit
hope this helped
Dec 15, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Pioneer AVIC-N2 Car DVD Player Logo
117 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
