Question about Brother HL 1260e Laser Printer
LEXMARK ALL-IN-ONE PRINTER X5250
Cartridge got jammed as I replaced it and I had to prise the cover over the cartridge up a little to get it released. Cartridge now ok but printer won't print and message appears on printer 'cover open'. Also - message on computer appears, saying: Push the scanner support in Lower the scanner unit to close Press continue button Have done this and checked scanner unit is securely closed but can't get rid of messages and printer won't print.
    Top Expert:
  • Brother Master
  • 83,850 Answers
YOU RUINED IT, REPLACE THE PRONTER.
Posted on Jun 20, 2017
Mix-it-up
  • 832 Answers
SOURCE: Changing ink cartridges
Do you use generic ink carts?
Those do make a lot of trouble with different errors.
Use another cart and it should disappear.
The technique of brother printheads demands some ink to keep the printhead working. Otherwise it will dry out. Therefore the machine runs some auto cleaning cycles (about once a week).
You should set date and time and leave the printer on power (You can turn it off by pressing stand-by-fax. But do not unplug/disconnect it from power outlet. Otherwise the printers logic thinks that if the printer is reconnected that it is newly initialized and pumps a lot of ink into the waistinktank).
The amount of ink when running auto cleaning cycles is about 1/10 of the amount of the initializing one!
Posted on Nov 08, 2007
checkitright
  • 1362 Answers
SOURCE: Back cover open message
there isa switch that is not being activated, open each door there is a small hole that have a switch , put a pice af paper in and activate the switch
Posted on Sep 02, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Posted on Jan 26, 2009
SOURCE: back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Posted on Feb 03, 2009
  • 6 Answers
SOURCE: Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Posted on Dec 17, 2009
Copies have blue background
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5200 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5250 flashing green power light
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Jan 25, 2012 | Lexmark Office Equipment & Supplies
CARTRIDEGE PROBLEM ERROR 1203
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Aug 30, 2011 | Lexmark X5250 All-In-One InkJet Printer
Hello my printer wont work, the powerbutton is blinking and i hear a tikking noise. is mij printer broken?? lexmark x5250
It could an alignment problem, a paper jam, or something blocking the paper path. Open the printer cover and remove both the cartridges. While the cover is open, check the cartridge area for any obstructions in the cartridge carrier's path. Check any transparent strip(encoder strip) that has become loose from its position. If there's nothing out of the ordinary, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges and make sure they properly inserted and secured. Close the cover and try to print again.
May 29, 2011 | Lexmark X5250 All-In-One InkJet Printer
My Lexmark x5250 printer does not work. It always shows 'cover open' message.
first check that all doors or covers are closed and then check the door switches if they all ok one of the door switches are either broken or faulty and needs to be cleaned, repaired or replaced
Oct 13, 2010 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5250 "cover open" problem
hi
there is a sensor in a hole under the cover (door)
you should find it
check it that shouldn't be jamed
check it with a pen or something like that
Jun 12, 2010 | Lexmark X5250 All-In-One InkJet Printer
It says invalid black cartridge, but I have a lexmark cartridge.
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Mar 05, 2010 | Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 Printer
chech to see if the cartridge slot locks down the tab that locks the cartridge have been known to break. or run a maintenance check and clean the printer heads.
Sep 27, 2008 | Lexmark X5250 All-In-One InkJet Printer
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
See all Brother HL 1260e Laser Printer Questions
Brother HL 1260e Laser Printer Logo
James Cagle
James Cagle
ctnozil
Victorman
Victorman
