Home | Keurig | B60 Coffee Maker | Keurig B60 cof...
Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
Keurig B60 coffeemaker stopped pumping water
By drmjsaunders on Nov 11, 2008
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the chamber. I turned it off and on, nope. Turned it off and unplugged it. Started over. Nope.
Same Problem
Jan 27, 2009
-   My Keurig will not pump any water at all.-   Guest
Jan 15, 2009
-   Unit was transported between homes and, after being plugged-in at the new location, it now fails to heat the water. Display says "Not Ready". Water never heats. Housing never feels warm.
Keurig offers no customer support other than a $29 discount on the purchase of a new machine. Incredible!-   dodger4
Best Solution
posted on Jun 21, 2009
Very Helpful)
fire2199
Rank: Apprentice
Rating: 78%, 8 votes
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 07, 2008
Very Helpful)
DrFeelGod
Rank: Master
Rating: 88%, 8 votes
The Keurig B60 wouldn't allow you to brew anything when the "Add water" is lit on the display.
You have tried without K-cups?
If yes and it still is a problem, it might be clogged somewhere. I.e residue from minerals. Try to rinse it with vinegar according to this:
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Was this helpful?
Yes
No
Solution #3
posted on Feb 06, 2009
Somewhat Helpful)
mormac0
Rank: Apprentice
Rating: 75%, 1 votes
push middle button and it will brew about quarter cup,stop for about 30sec then finish brewing
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
only a week old. for the last couple of days will not brew a cup of any size. shows brewing on lcd,... (More)
Answer
The Not Ready indicator will not go off and the coffee will not brew. I have unplugged and replugged... (More)
Answer
Lost the part the coffee pod sits in and cant find a replacement anywhere on the net or and any... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keurig B60 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
