Question about Maytag MGS5870 Gas Kitchen Range
OVEN NEVER REACHES TEMPERATURE SETTING
WHEN I SET THE OVEN TEMPERATURE AND TIMER, MY FOOD IS NEVER COOKED ENOUGH. THE PANEL SHOWS THE HEAT TEMPERATURE RISING AND BEEPS WHEN IT SUPPOSEDLY REACHES THE SET DEGREES. I HAVE HAD FOOD IN FOR AN HOUR AND OTHER FOODS UP TO SIX HOURS AND NONE OF IT WAS READY TO EAT. COULD IT BE THE IGNITOR AND/OR IS THERE A TEMPERATURE SENSOR THAT COULD BE RESET OR NEEDS TO BE REPLACED? WHERE ARE THE IGNITOR AND SENSOR LOCATED? IS THIS SOMETHING THAT WE COULD DO OURSELVES? THANK YOU SO VERY MUCH!!!
  • Anonymous Feb 06, 2009
    food never cooks in the time allowed
I read my wonderful "user's guide". In the section, Controls at a Glance, I found OVEN TEMPERATURE ADJUSTMENT OPTION & followed 5 easy sets. It worked!!!
Posted on Nov 12, 2008
I have a microwave in which i have option only for timer no option for setting temperature how to use it
Unlike a conventional oven, your microwave does not have a provision for setting a specific temperature. There may be only settings for different levels of heating such as high and medium and a special setting for thawing frozen food. The manual for your microwave could be a useful source of information regarding operation.
Dec 02, 2014 | In Microwave Ovens
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
    hello,
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
    KGST307 gas stove has a temperature control problem.
    the least expensive fix would be to buy an oven thermometer and note what setting is needed to attain 350 degrees and go from there. please rate me
    Jan 06, 2009 | KitchenAid KGST307 Gas Kitchen Range
    Maytag MGS5870 Gas Kitchen Range Logo
    349 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
