Hi there my toner cartride is jammed and will not rotate to get it back into a position where I can remove it. It is as if it has not seated in place or is slightly too long and now it is wedged against the edge of the hole where you insert the cartridges and will not budge back or forward - stuck! I have pressed in the little catch that usually allows me to rotate them into posiion in and anti clockwise direction but because the cartridge is jammed against the edge it will not rotate at all. Any ideas how to get it out - solve the problem??
unfortunatly these little printers are i real pain when somethign goes wrong inside. to access the toner you will need to take out the waste collector, transfer belt, developer unit, remove front door then oyou should be able to remove the grey plastics that only alow you access to one toner at a time. you should now be able to rotate the carousel to a point where you are able to remove the jammed toner.
After clearing a very difficult paper jam in the heated rollers the machine has blinking red and...
(More)
After clearing a very difficult paper jam in the heated rollers the machine has blinking red and green lights and reports a 6025 error - any advice?
when colour printing colours hve changed e.g. green is turning slightly blue, red is slightly...
(More)
WHEN COLOUR PRINTING COLOURS HVE CHANGED E.G. GREEN IS TURNING SLIGHTLY BLUE, RED IS SLIGHTLY PURPLE! HELP!
I have an epson aculaser c900 with a photoconductor unit that appears to be stuck in the printer. Is...
(More)
I have an epson aculaser c900 with a photoconductor unit that appears to be stuck in the printer. Is there another way of getting this out of the printer. I have tried pulling this out using the tab on the pcu and with the fuser in unlocked position but the pscu appears to be jammed in.
