Question about Brother HL 1260e Laser Printer
BROTHER LASER PRINTER HL-1260
Message appearing on printer: high vol malf printer has red light and wont print.
WHEN YOU OPEN THE PRINTER THE TRANSFER ROLLER THAT IS AT THE FRONT BY THE METAL FLEP NEEDS CHANGING. THIS IS WHAT CAUSES THE HIGH VOL MALF. HOPE THIS HELPS.
Posted on Sep 27, 2007
SOURCE:
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Brother HL 5240 Laser Printer Hi I hope you can
Hello
You need to re-install drivers of the printer. also check the USB cable.
Good Luck
Jan 07, 2011 | Brother HL-5240 Laser Printer
Printer Won't Print
Follow the link below for what the lights on the machine mean. I know that if your alarm and data light are on it means the toner is empty, and you wont be able to print, you would need to replace the toner cartridge, please follow the link below.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1440_all
Apr 17, 2010 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Alarm light on
you have mailfuncton on the printer,you don have a high voltage on corona vire ,call some service man
Feb 07, 2008 | Brother HL 1660e Laser Printer
Brother HL 1260e Laser Printer Logo
158 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
