Question about NorStar T7316E Corded Phone
Changing Personal Greeting
I want to record a new greeting on our main phone line. I go to "Feature" and enter "983", but when I enter the Log "1020000#" like is says in the instructions I have, I am told I have entered an incorrect password and am kicked out of the system. Any advice?
Someone has changed the default admin mailbox. Call in a Nortel Vendor, let me know if you need one as I can get techs all over the country.
Posted on Nov 19, 2008
I want to delete an existing greeting message on the autoattendant. How do I do that?
Okay, it sounds like you're using a standard auto attendant greeting setup.
Try this:
Feature 983
Password: 1020000 (or whatever you have recorded for the password)
Select AA
Select Greeting
Select Greeting again
Enter 1 (for Greeting 1)
You can hit Play to ensure that you are listening to the correct greeting. If not, select another greeting by enter the number 2 for greeting.
Once you have found the greeting that you would like to erase, simply press record and let it record one or two seconds of silence. The greeting will be gone. Press OK to accept the new greeting (silence) and exit the system.
May 13, 2014 | NorStar Startalk Flash 2 Phone
How do I change voicemail greeting on Nortel Model T7316 phone?
feature 981
enter password
listen for promt to change greeting.
for main greeting
press feature 983
if 3 digit extensions enter 1020000 if 2 digit extensions enter 120000
press AA
press grtg
press 1
press rec
press ok to end recording
press ok
press rls
To Listen to the Greeting, press Play. To ReRecord, press RETRY. Press OK to accept Greeting.
Jan 11, 2011 | Nortel Lands Phones
Need directions for recording the greeting on the main line of system
To enter voicemail administration, press Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. Once you have entered the password you will see 3 selections you can make .Use the three soft keys under the display and select AA (auto Attendant). Next, press greeting and greeting again. Next, it'll ask for the greeting number your probably working with greeting 1. Press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Sep 30, 2010 | NorStar M7208 Corded Phone
I am trying to change the out going message How do you change the greeting?
To re-record the main greeting, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
May 03, 2010 | NorStar T7316E Corded Phone
The automated recording that comes on when the lines are full needs to be changed and the recording of an employees name on the directory needs to be changed. I have already changed the display name on the...
The persons name is recorded in their personal mail box.Thats done by pressing open voicemail or feature 981 followed by their password, press 8 or admin and press 1 to re record thier name in the company directory.
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Apr 06, 2010 | NorStar M7310 Corded Phone
Changing the greeting on the company's main phone
Dec 17, 2009 | NorStar M7310 Corded Phone
How do I change the main greeting from greeting 1 to greeting 2?
You have to go to vmail prog. Press feature 983 from main tel set enter passwrd press aa press greatings type in a 2 record your greeting you will have to rerecord over greeting 1 if you want to chg it .you know how to assign it to a time of day greeting table if not give more info
Nov 24, 2009 | NorStar M7310 Corded Phone
How to remove the old corporate greeting in T7316 Nortel?
Press Feature 983 enter admin password
press AA
press Grtg
press Grtg again
press 1 then ok.
Greeting 1 is usually for day and 2 is usually for night depending on the tech who set it up.
May 17, 2009 | Nortel T7316E 2-Line Corded Phone
Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
Feb 25, 2009 | NorStar M7310 Phone
Change voice message on nortel meridian phone system
You need to go in to voice mail admin .
Feature 983 1020000
press AA
press Greeting
press greeting again
enter 1 for greeting 1
this should be your main greeting it could any greeting from 1- 20 , it depends on how it was set up but that should work fine .
Feb 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
NorStar T7316E Corded Phone Logo
206 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
