Question about Proview HX303 30 in. HD-Ready LCD Television
Pink lines sometimes
I have a Proview RX-326. It is a 32" LCD that sometimes has a 6" wide vertical red line and a lighter, pink, 3" wide vertical line about a 1/3 of the way from the edge. It is completely random when the problem happens. Usually when I am changing a channel, the next channel will show this red. I can still see all of the picture, just not in the right color in this area. Could this be a transistor or lamp problem? Thank you.
5 Suggested Answers
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
SOURCE: no picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Posted on Jan 28, 2009
  • 17 Answers
SOURCE: turns off and on
If it happens at a certain time every day, make sure you do not have the sleep and wake timers on.
Posted on Mar 08, 2009
  • 8457 Answers
SOURCE: does the proview rx-326 have the digital box
Yes,it have a Digital Tuner inside.It can get free air signal tv.No,need for a converter box like a Analog CRT tvs.
Posted on Apr 07, 2010
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Screen sometimes has vertical red lines through
Sounds like you have a broken LCD screen. Somebody needs to open your blackberry to replace it. Go to your provider, they might replace the phone for you. If they refuse and If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry pearl Repair Guide that shows how.
Apr 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
50. In LCD samsung has pink vertical lines
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Mar 03, 2010 | Samsung LN-T4665F 46 in. LCD Television
23HLV86/DVD Pink vertical line 1/4 way in from
If this is a LCD Flat Panel TV, the LCD Panel it self would probly need to be replaced.
Skyassoc
Sep 12, 2009 | Televison & Video
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
I have vertical lines on my laptop two of them one Is clear and the other is kind of red or pink
bad LCD matrix, you need to change matrix. It's called dead lines of LCD
Apr 15, 2009 | Computers & Internet
My Xerox 6130 keeps printing vertical pink lines on pages
your color laser printer pink vertical line appear on the roller and film drum,
1) you need check the pink drum surface, it got damage if you find there is a different color vertival line on the drum surface, so you need change the pink drum.
2) check the pink drum cleaner (call brush to return the waste toner), it can not clean well sometimes, if the drum surface good.
Feb 06, 2009 | Xerox DocuColor 12 Printer
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Proview HX303 30 in. HD-Ready LCD Television Logo
20 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Paul
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
